Grinding Noise When Pulling Away From Stop.
- adamjimny
25 Nov 2013 14:28 #93107
by adamjimny
Replied by adamjimny on topic Grinding Noise When Pulling Away From Stop.
its the rear gearbox mount. makes the gearbox-transfer propshaft rub on the gear selector mounting when its turning but only under load. about 37 quid from suzuki last time i checked. i had same problem last year.
- jonesyba420
25 Nov 2013 14:41 #93109
by jonesyba420
Replied by jonesyba420 on topic Grinding Noise When Pulling Away From Stop.
is it something easy to check at home on the drive? mine makes a random noise when i pull away, hard to describe it really! only when initially pulling away as soon as im moving no noise. could wheel bearings or kingpins make a random noise when pulling away? i know wheel bearing start as a whine and get progressivly louder the more fu#*$* they get and kingpins we all know about but could it be related?
- Jimnyash
26 Nov 2013 08:02 #93267
by Jimnyash
Replied by Jimnyash on topic Grinding Noise When Pulling Away From Stop.
Interesting you guys mention squeaky bushes. Do you think some muck could have got into/around them?
The noises didn't start until after a very muddy track....
I'm wondering if a good powerwash under the wheel arches may help?
- Barrygsi
26 Nov 2013 11:23 #93291
by Barrygsi
Replied by Barrygsi on topic Re:Grinding Noise When Pulling Away From Stop.
Get under it and try pushing the rear of the gearbox up towards the body. If it moves and hits the body then the bush must be split
Sent from my GT-I9100P using Tapatalk
- adamjimny
26 Nov 2013 23:15 #93380
by adamjimny
Replied by adamjimny on topic Re:Grinding Noise When Pulling Away From Stop.
Yes sort of look onto of the prophet for fresh rub marks.
sent using my Z1 using Tapatalk
- Jimnyash
04 Dec 2013 18:39 #94544
by Jimnyash
It looks as though it was indeed the rear gearbox mount.
Thanks guys.
Thanks guys.
Time to create page: 1.469 seconds
