Grinding Noise When Pulling Away From Stop.
  • Barrygsi
24 Nov 2013 18:59 #92984 by Barrygsi
Replied by Barrygsi on topic Re:Grinding Noise When Pulling Away From Stop.
Rear gearbox mount worn/split? This allows the gearbox to lift and twist under load and it touches the body causing a noise momentarily when accelerating/pulling away.
Sent from my GT-I9100P using Tapatalk
  • Licksan
24 Nov 2013 19:37 #93004 by Licksan
Replied by Licksan on topic Grinding Noise When Pulling Away From Stop.
Sounds like the clutch is on its way out...
  • Jimnyash
25 Nov 2013 07:46 #93067 by Jimnyash
Replied by Jimnyash on topic Grinding Noise When Pulling Away From Stop.
Licksan wrote: Sounds like the clutch is on its way out...
Clutch checked. All OK.
  • Yellostreak
25 Nov 2013 08:44 #93071 by Yellostreak
Replied by Yellostreak on topic Grinding Noise When Pulling Away From Stop.
if its driving ok then I think it might be a brake binding or something.. possibly crud in the drums as previously mentioned..
also try spraying all the suspension bushes with a bit of soapy water.. if one of the bushes is causing it then the noise will go away for a short time... this could also be an indicator as to why it is intermittent (dry/wet days??)
  • trextr7monkey
25 Nov 2013 13:59 #93100 by trextr7monkey
Replied by trextr7monkey on topic Grinding Noise When Pulling Away From Stop.
Spray bushes with silicon spray for slightly longer cure also deals with any squeaky dash boards, should sucha problem ever become evident in your Jimny :D
atb
Mike
  • jonesyba420
25 Nov 2013 14:07 #93104 by jonesyba420
Replied by jonesyba420 on topic Re:Grinding Noise When Pulling Away From Stop.
Barrygsi wrote: Rear gearbox mount worn/split? This allows the gearbox to lift and twist under load and it touches the body causing a noise momentarily when accelerating/pulling away.
how do you check this?
Time to create page: 0.322 seconds
