Fitting M15A VVT engine into non VVT M13A Jimny
  • Smoggy
23 Jul 2013 20:43 #78028 by Smoggy
Hi guys.
I have recently experienced some big problems with my Jimny when my engine started knocking, overheating and quickly seized after a local garage recommended, supplied and fitted an M15A VVT engine to my non VVT 2000 plate M13A Jimny. The garage will not accept any liability. Before I take the matter up with my local trading standards department does anyone know if it is in fact possible to do the above conversion without changing the ECU. What is the likely outcome of the engine change please? Seizure perhaps?
Many thanks in advance guys.
  • Smoggy
23 Jul 2013 21:06 #78029 by Smoggy
Please note after doing some more checking I have also noticed that when I switch on the ignition the engine management light no longer comes on! It definitely did light before the engine was changed. I am going to check the bulb as soon as I get chance... if it's still there!
I am uncovering more and more issues with this and am now determined to get to the bottom of it.
  • Hastiekid
24 Jul 2013 16:24 #78077 by Hastiekid
Replied by Hastiekid on topic Fitting M15A VVT engine into non VVT M13A Jimny
Sad to hear you are getting poor customer service Mate. As I have said before this garage is very local to me and I had considered getting them to fab a cage for me but who wants to give work to a garage that treats customers badly ?
All I can say is word gets round so Its worth treating customers properly.
  • Vacneb
24 Jul 2013 17:20 - 25 Jul 2013 14:47 #78080 by Vacneb
I reckon this is an oddball case. My auld man just had a rear crossmember done on his 90 without an issue - even done some fault finding on a diesel/oil leak and an exhaust repair all done by the same garage... Im not saying either party is right or wrong - this is just to tell of my experience. The price he was charged has me planning a trip to them for a disc upgrade and stainless exhaust in the near future.
I hope you do get a resolution Mike, and that relations are made good again :)
Last edit: 25 Jul 2013 14:47 by mlines.
  • Dave cc
24 Jul 2013 17:59 #78086 by Dave cc
There an old adage you are only as good as your next job
And when you sod somthing up that is the one you will always be remembered for so best pay the dues and keep your reputation in shape imo
  • RichiesJimny
24 Jul 2013 18:25 - 24 Jul 2013 18:35 #78087 by RichiesJimny
Replied by RichiesJimny on topic Fitting M15A VVT engine into non VVT M13A Jimny
Dave cc wrote: There an old adage you are only as good as your next job
This is very true Dave, I've always said if you do a good job your name will get passed on to one or two people but do a bad job and they will tell ten or twenty people.
As for fitting a vvt engine in a none vvt car I would hope any garage that knows anything about engines would know its not going to run properly as they run different engine management systems.
Yes it will run but not properly as the timing and fueling will be all over the place.
Last edit: 24 Jul 2013 18:35 by RichiesJimny.
Time to create page: 0.523 seconds
