Fitting M15A VVT engine into non VVT M13A Jimny
25 Jul 2013 19:20 #78206
by Rhinoman
The ECU opens a valve that lets the oil through and the oil pressure operates the VVT. I haven't really looked at how the ECU controls this, I would have expected that the ECU would use the phase difference between the cam and crank sensors to confirm that the VVT has operated, there is a fault code for this but it may only be available via the OBD1 protocol so you'd need a factory scan tool.
Replied by Rhinoman on topic Fitting M15A VVT engine into non VVT M13A Jimny
markyp2000 wrote: Does the vvt work off the ecu or by oil pressure if its oil pressure then it wouldnt make any difference would it?
- Dave cc
25 Jul 2013 23:06 #78230
by Dave cc
That how i beleive it works only knowledge i have had is with BMW Vanos that does have electrical actuation valves
Replied by Dave cc on topic Fitting M15A VVT engine into non VVT M13A Jimny
26 Jul 2013 10:30 #78243
by Rhinoman
It looks like the ECU operates it based purely on RPM. The engine has two distinct power curves for the two cam positoins, at the RPM at which they cross the power is the same. The ECU operates the valve at that point so there is no step change in the power output.
The following user(s) said Thank You: Smoggy
Time to create page: 2.042 seconds
