Fitting M15A VVT engine into non VVT M13A Jimny
- supergaz
24 Jul 2013 18:40 #78090
by supergaz
Replied by supergaz on topic Fitting M15A VVT engine into non VVT M13A Jimny
Its easy to pick up a liana m16 non vvt block.
24 Jul 2013 19:45 #78101
by Rhinoman
Replied by Rhinoman on topic Fitting M15A VVT engine into non VVT M13A Jimny
Did they use the original head?
- gaz3359
24 Jul 2013 20:08 #78107
by gaz3359
Replied by gaz3359 on topic Fitting M15A VVT engine into non VVT M13A Jimny
This is not good news mike,shame you cant get any help.id agree with rich,for it to run perfect you'd ideally need the full harness ecu pick up ring etc etc from the donor car bit different from dropping an m16a which is just plug and play.but weather this could have caused it to fail different matter loads of factors to be taken into concideration.
- Smoggy
24 Jul 2013 20:44 #78114
by Smoggy
Replied by Smoggy on topic Fitting M15A VVT engine into non VVT M13A Jimny
Yes thanks for all the comments Guys. I have just spoken with Suzuki technical support today and they said that my model of pre VVT Jimny would never work properly with the M15A VVT engine that was installed. I just wish I had been given the choice whether or not to proceed when they realised my car was non VVT ( which should have been when they looked at the registration plate and saw it was pre 2005.
In addition to this and after having the car checked over by a local mechanic the oil filter has been on perpously stoved in to make it fit around the engine mount (when all you really need to do is fit the filter side on to the engine like the jimny), the car had starting problems and when examined one of the studs had stripped its threads causing the cable to be a loose fit, A top engine lifting support was rubbing into the top radiator hose and would have worn through, the lower steel panel covering the engine clutch housing was missing causing silt and mud to enter the clutch, the battery terminals were loose and now the engine management light wont come on when you turn on the ignition (I have yet to check if the bulb is still in), A bolt securing the exhaust manifold to the chassis was missing.
That's all I can remember for now, apart from that and the VVT issue it looks okay
- Smoggy
24 Jul 2013 20:48 #78116
by Smoggy
Oh and Rhinoman. No the cylinder head from the VVT Swift/Ignis was fitted along with the engine.
- gaz3359
24 Jul 2013 21:03 #78121
by gaz3359
Time to create page: 1.758 seconds
