Fitting manually operated freewheeling hubs
  • Ryanc1660
09 Feb 2014 10:36 #103946 by Ryanc1660
Replied by Ryanc1660 on topic Re:Fitting manually operated freewheeling hubs
I have a quick question on his matter, I have purchased a set of manual operating avm hubs off eBay and separately ordered 2 pairs or 5mm washers. Both of which havnt come home with either cone washers or bolts. My question is if I purchase the right bolts m8x30, do you really need the cone washers? Can younot just put a normal washer on and screw it tight?
09 Feb 2014 14:08 #103981 by robs5230
they do need to be fitted with the cone washers. not sure whether martin carries them
standard jimny - for now
  • minitehnicus
09 Feb 2014 17:07 #104000 by minitehnicus
Replied by minitehnicus on topic Fitting manually operated freewheeling hubs
what is the thickness of the spacer ring ? thx
  • GuardianAngel
09 Feb 2014 17:15 #104002 by GuardianAngel
Replied by GuardianAngel on topic Re:Fitting manually operated freewheeling hubs
robs5230 wrote: they do need to be fitted with the cone washers. not sure whether martin carries them
JimnyBits do them.
09 Feb 2014 22:14 #104061 by robs5230
bigjimny shop carries the spacers but not the cone washers ( i think)
www.4x4liftkits.co.uk/store/index.php?_a=product&product_id=15
  • Ryanc1660
09 Feb 2014 22:29 #104069 by Ryanc1660
Thanks for your replys. I accidentally said I had ordered 2 pairs o 5 mm washers, I ment 2 pairs of 5 mm spacers! But I will just order that cone washers to keep things right. I see them on jimny bits so will get them ordered, cheers.
Time to create page: 0.385 seconds
