Fitting manually operated freewheeling hubs
  • helijohn
03 Jul 2013 16:40 #75951 by helijohn
Replied by helijohn on topic Fitting manually operated freewheeling hubs
I would still like to know why the operating lever was unable to move less than halfway from 'free' to 'lock' and why the hub was locked or should I say jammed. And if it got jammed (say in transit) why? :unsure:
  • vitara_mad
03 Jul 2013 18:24 #75974 by vitara_mad
Replied by vitara_mad on topic Fitting manually operated freewheeling hubs
sounds like they have been taken apart & not put back together right
  • helijohn
03 Jul 2013 20:55 #76007 by helijohn
vitara_mad wrote: sounds like they have been taken apart & not put back together right
I thought that especially as the bolts were loose, too loose in fact for use on the wheel. Trouble is I don't see how it could be assembled physically incorrectly; it just wouldn't go together. :unsure:
03 Jul 2013 22:02 #76021 by dirtydogz
BigJimny is free and will remain free. However, if you have enjoyed this forum you may wish to make a small donation to keep it running. Note: if you have purchased an item from the shop then you have already contributed to the running of the site.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
  • helijohn
03 Jul 2013 22:12 #76028 by helijohn
dirtydogz wrote: if you have enjoyed this forum you may wish to make a small donation ............purchased an item from the shop then you have already contributed to the running of the site.
As I hope you enjoy my contributions; I think I get the idea. ;)
  • helijohn
10 Jul 2013 14:40 #76597 by helijohn
Replied by helijohn on topic Re:Fitting manually operated freewheeling hubs
ne-crock wrote: Mine are alan bolt,
And at a guess i'd say fine, due to most bolts on the jimny are fine thread
Well I can say that they are M8 x 0.75P which is fine. There are apparently two fine pitches, 1 and 0.75. The 0.75P are a lot harder to get.
Time to create page: 0.156 seconds
