Fitting manually operated freewheeling hubs
- markyp2000
26 Jun 2013 07:06 #75132
by markyp2000
Replied by markyp2000 on topic Re:Fitting manually operated freewheeling hubs
To get the torx bolts off use a 12 sided 8mm socket or there abouts
26 Jun 2013 11:18 #75145
I curse the day torx was developed.
Replied by helijohn on topic Re:Fitting manually operated freewheeling hubs
markyp2000 wrote: To get the torx bolts off use a 12 sided 8mm socket or there abouts
- Johnniehec
- Thank you received: 56
27 Jun 2013 20:03 #75292
by Johnniehec
Replied by Johnniehec on topic Re:Fitting manually operated freewheeling hubs
I've had my hubs off several times, an imperial 5/16 socket fits just fine
27 Jun 2013 20:24 #75300
Replied by helijohn on topic Fitting manually operated freewheeling hubs
What do we think to cutting down the Jimny bolts to fit with the SJ hubs?
- Swifty
28 Jun 2013 06:56 #75318
by Swifty
Replied by Swifty on topic Fitting manually operated freewheeling hubs
If you get the adapter plates they come with new bolts.
28 Jun 2013 08:20 #75323
The plates are coming with the hubs.
However, it could be a while because the seller hadn't set up his account to take Paypal and so it looks like there is a delay.
I won't tell you what I am thinking as it is almost unprintabale but this guy doesn't even seem to think there is any urgency. Another ebay tosser.
Swifty wrote: If you get the adapter plates they come with new bolts.
Time to create page: 0.149 seconds
