Trailmaster vs. Black Raptor
18 May 2020 18:30 #222502 by Busta
Replied by Busta on topic Trailmaster vs. Black Raptor
My 2 pence worth...
Trailmaster are a well established and well respected company that have been making their own products to a very high standard for a number of years. They are fully type approved. I've never heard a bad word about them.
Black Raptor first came to my attention a few years ago with some badly aligned stickers stuck on some generic shocks. They don't have a website. Their name is very similar to an existing 4x4 parts brand, but they aren't associated in any way. Very little information is available about their products or the brand.
Which will perform better? I have no idea, but I know where I'd rather spend my money.
  • Lasse
18 May 2020 18:42 #222503 by Lasse
Replied by Lasse on topic Trailmaster vs. Black Raptor
Well i see Your point.!
But am i right that when you see the Jimny From a side view it look like the front is sits lower than back when fitted with the Trailmaster 50mm kit..
Must say I’m going for the slight raised look rather the ultimate flex..!
18 May 2020 19:06 #222506 by 300bhpton
Busta wrote: My 2 pence worth...
I believe Black Raptor is Jimnybits kit. At least that is what they told me. They shocks they spec from a shock maker and kit is built to their design/spec.
18 May 2020 19:11 #222508 by mlines
Replied by mlines on topic Trailmaster vs. Black Raptor
If you saw the Trailmaster "before" video you will have seen
82cm rear arch to ground
79cm front arch to ground
98cm door handle base to ground (probably 97.5cm after reviewing the video again)
After lift (which has not been published yet)
87cm rear arch to ground = +50mm
83.5cm front arch to ground = +45mm
102cm door handle base to ground = +45mm (as corrected above).
If the wheel arch measurements are correct and the front and rear wheel arches are lined up, then it is 3cm lower at the front in its unmodified version anyway
18 May 2020 19:19 #222509 by X8GGY
Replied by X8GGY on topic Trailmaster vs. Black Raptor
"Black Raptor" Is indeed a JimnyBits brand... RLP (Russell Lee Palmer) Engineering / 4x4 Outlet... all one and the same...
  • Lasse
18 May 2020 19:32 #222511 by Lasse
Maybe it’s just some bad angles or whatever but those two looks a lot lower in the front..! Sorry for the bad pics it’s screenshots from YouTube..!
Time to create page: 2.616 seconds
