Trailmaster vs. Black Raptor
19 May 2020 17:08 - 19 May 2020 17:08 #222547
by sniper
Replied by sniper on topic Trailmaster vs. Black Raptor
The new bushes are easy to get in, the old ones are a bugger to remove....
If you haven't got access to a press, the method most use is to drill the rubber out, slit the outer casing with a hacksaw and fold it in to release it. Pretty easy to do with simple tools.
The poly bushes are in two parts and simply push in by hand, the steel steel centre bush holds them together when they are loose...
sniper
sniper
Last edit: 19 May 2020 17:08 by sniper.
19 May 2020 18:02 - 19 May 2020 18:03 #222548
by Scimike
Replied by Scimike on topic Trailmaster vs. Black Raptor
As Sniper said, drill out the rubber and then hacksaw outer casing. I've done quite a few like this on my Land Rover, you can get them out fairly quickly and Polly bush are a dream to fit after.
The only suggestion is use a hole saw (pick size to go over centre bush) rather than a drill. It's quicker and you can't snap it off in the rubber which is always possible with a drill.
Like this
www.screwfix.com/p/erbauer-multi-materia...w-uNTIhoC8W4QAvD_BwE
But get correct size!
Mike
Like this
Mike
Last edit: 19 May 2020 18:03 by Scimike.
19 May 2020 18:45 #222549
Replied by Soeley on topic Trailmaster vs. Black Raptor
Thanks, I was actually more worried about fitting the new ones once the old was out. I have never used Polly bushes before so was worried how much pressure is needed to get them in.
Is it best to fit them assembled or fit the Polly outer first, then press in the steel insert?
- Thank you received: 1876
19 May 2020 19:08 #222551
Replied by Lambert on topic Trailmaster vs. Black Raptor
I had to replace a couple of arm bushes for a mot a fee years ago. I did the first with all thread and nuts etc. I bought a press to do the others.
19 May 2020 20:04 #222553
Just found these videos, I really didn't think they would go in that easy going by the feel of them.
19 May 2020 20:30 #222554
by sniper
Soeley, sorry mate those are one piece... You will have to use a threaded bar and socket, if you don't have a press..... Spoke before I saw...
sniper
sniper
Time to create page: 0.205 seconds
