Trailmaster vs. Black Raptor
  • Grima
18 May 2020 20:57 #222514 by Grima
Replied by Grima on topic Trailmaster vs. Black Raptor
Black Raptor yes, Trailmaster what's the point in a 2" lift then fit a 1" bump stop on the front???????
18 May 2020 21:16 - 18 May 2020 21:19 #222515 by mlines
In my opinion the bump stops are an integral part of a live axle suspension. It is possible to over compress a spring or punch through the end stop of a shock on the compressing side.
Once the compressed side stops compressing against the bump stop then the car starts to transfer weight to the extending side which you want (to a point, you don't want to roll of course). You need to other side to have weight on it so the wheel grips the surface. I have seen some "high flex" which are really just where a wheel has dropped to the ground ("great flex mate!") but then just spins the wheel as there is no downside on it.
On my 3.5 inch lift on the Gen3 Jimny, extended bump stops have definitely improve the way it crosses bumpy ground
Last edit: 18 May 2020 21:19 by mlines.
  • Grima
18 May 2020 21:34 #222516 by Grima
Replied by Grima on topic Re:Trailmaster vs. Black Raptor
Front axel hitting front brace member. That's where Trailmaster were to quick to offer a lift kit. All other 50mm kits compensate for this.
18 May 2020 21:37 - 18 May 2020 21:41 #222517 by mlines
Sorry, but I have not seen the 50mm Trailmaster hit the prop, I will keep an eye on it of course.
Last edit: 18 May 2020 21:41 by mlines.
  • Grima
18 May 2020 21:58 #222518 by Grima
In other kits brackets for lowering the front brace member are fitted so there is no need to add extra bump stops on the front axel. Therefore losing no articulation.
  • Lasse
18 May 2020 21:58 #222519 by Lasse
Replied by Lasse on topic Trailmaster vs. Black Raptor
What about the steering damper - anyone who has upgraded that when fitted a lift kit..?
Time to create page: 1.570 seconds
