1.3 to 1.5 commonalities
23 Jan 2019 06:04 - 23 Jan 2019 06:05 #201473 by yakuza
Replied by yakuza on topic 1.3 to 1.5 commonalities
Riccy wrote: KAP are taking apart one to make a pickup.
Interestingly the axles are 40mm wider than before, but identical otherwise.
Funny.. 40mm is the same change as the SJ to Samurai in 1988. Springs where moved out in 1988 to add stability.
Would expect that to be the case now as well, but might be just for looks.
Last edit: 23 Jan 2019 06:05 by yakuza.
23 Jan 2019 06:48 #201475 by Lambert
Replied by Lambert on topic 1.3 to 1.5 commonalities
So what that means is that even if the diffs are the same the half shafts will be longer. Do we know if the spring seats and radius brackets are in the same relative position to allow the axles to be swapped whole to offer a better solution than offset wheels or spacers?
23 Jan 2019 10:49 #201502 by saxj
Replied by saxj on topic 1.3 to 1.5 commonalities
Stuff that I know is interchangeable...
1. Wheels (and wheels nuts)
2. Coils
3. Shocks
23 Jan 2019 11:23 #201505 by mlines
Replied by mlines on topic 1.3 to 1.5 commonalities
Lambert wrote: So what that means is that even if the diffs are the same the half shafts will be longer. Do we know if the spring seats and radius brackets are in the same relative position to allow the axles to be swapped whole to offer a better solution than offset wheels or spacers?
One of the earlier press releases talked about some re-positioning of the mounts but visually they seem pretty much the same so it could be mm rather than cm of change.
23 Jan 2019 11:46 #201507 by Lambert
Evolution of design rather than revolution of design kinda thing. I wonder what else has been improved that could be incorporated into the 1.3? Are the front brake rotors vented by any chance?
23 Jan 2019 12:09 #201508 by saxj
Lambert wrote: Evolution of design rather than revolution of design kinda thing. I wonder what else has been improved that could be incorporated into the 1.3? Are the front brake rotors vented by any chance?
Nope brake rotors are solid. I haven't got out the measuring tape yet, but I'm pretty sure they are exactly the same as the old model.
Time to create page: 0.341 seconds
