1.3 to 1.5 commonalities
saxj wrote:
Lambert wrote: Evolution of design rather than revolution of design kinda thing. I wonder what else has been improved that could be incorporated into the 1.3? Are the front brake rotors vented by any chance?
Nope brake rotors are solid. I haven't got out the measuring tape yet, but I'm pretty sure they are exactly the same as the old model.
Which actually is the same front brakes as the SJ from 1985. I had a 1985 caliper bracket on mine for years..
- Thank you received: 1885
Anyone know of anything else?
Bob1050 wrote: If the 2013 - 19 model year rubber floor mats don't fit the new model - it might be that the floor pans aren't identical?
Floor pan is definitely not the same
Lambert wrote: It being body on frame though it doesn't matter how much the body has changed if as seems to be the case the frame is mostly identical allowing intergenerational component compatibility.
The frame is not even close to the same. It is a total redesign.
