1.3 to 1.5 commonalities
- Thank you received: 1889
22 Jan 2019 15:41 #201413
1.3 to 1.5 commonalities was created by Lambert
For my edification and interest has anyone found or indeed published an list of compatible components between the two Jimny's? What I'm meaning is things like front hubs, differentials, transfer cases, springs, dampers, brake pads and calipers even axle casings? I'm not able to volunteer to do a comparison but it would be useful if we knew what swaps and what doesn't for example if 1.5 diffs would allow a 1.3to run 29 inch tyres and retain sensible gearing or if 1.3 manual hubs fit directly to 1.5 knuckles, if the 1.5 front axle has eradicated the king pin degradation issue and would fit the 1.3?
I have looked at the Japanese sites but even with Google translate I'm out of my depth. Anyone know of anything useful?
22 Jan 2019 16:45 #201418
Replied by mlines on topic 1.3 to 1.5 commonalities
At first look (a quick crawl underneath) it looks like a new body and engine bolted on top of the old running gear.
BAsed on the pictures of Japanese companies buying the Jimny on the morning of launch day in Japan and running them around on large tyres with a lift in the same afternoon it sounds like a direct fit for existing parts.
Only a guess.
Only a guess.
- Thank you received: 686
22 Jan 2019 16:58 #201421
Replied by jackonlyjack on topic 1.3 to 1.5 commonalities
Russ at jimnybits took delivery of one yesterday
So i'm sure he will be up dating his website soon
22 Jan 2019 17:07 #201422
Replied by Lambert on topic 1.3 to 1.5 commonalities
So from that we can interpolate that but for the engine and main gearbox more or less all modifications are interchangeable between the two cars?
22 Jan 2019 17:13 #201424
Not sure what will be inter changeable
but i'm sure he will list that it also fits 4th gen jimny
22 Jan 2019 18:54 #201432
Replied by Riccy on topic 1.3 to 1.5 commonalities
KAP are taking apart one to make a pickup.
Interestingly the axles are 40mm wider than before, but identical otherwise.
Time to create page: 0.169 seconds
