Lift Kit shopping list
03 Jan 2018 05:01 #187986 by Lambert
Replied by Lambert on topic Lift Kit shopping list
It's not just the free length of the spring its also the wire diameter and number of coils that make a difference. Stock spring wire is 10mm and lift spring wire is 12 13 or even 15mm so it is going to be stronger and compress less from the same starting point with the same load. There are equations that allow it to be calculated but 5am is way too early for that.
  • TomDK
03 Jan 2018 07:29 #187991 by TomDK
Replied by TomDK on topic Lift Kit shopping list
But of course.. thought that was obvious.
Spring rate calculators are easily found online and can be a great help when figuring out what springs to choose.
03 Jan 2018 08:07 #187993 by Lambert
It is to me , I was just posting for clarity for those with a less technical inclination.
03 Jan 2018 08:16 #187995 by Busta
Replied by Busta on topic Lift Kit shopping list
11/60 wrote: From how you have described the suspension on yours in the past with the fronts on the back I was expecting a hotrod esque raked nose down stance, but in the picture it's almost level?
Yes, it's quite subtle. My Jimny's have always sat low at the rear anyway and I prefer the level look. It probably helps that the springs on the back are off another used Jimny so will already have a bit of sag.
furo wrote: Busta - that looks awesome. I think if I were to replace my 2004 with a newer Jimny I would do what you have done there. Have you done any other modifications?
2-low switch, home made roof bars. That's it. Works perfectly well for me just how it is! Only thing I will be doing is fitting a 1.6 as and when I get the chance.
  • TomDK
03 Jan 2018 09:43 #187999 by TomDK
11/60 wrote: It is to me , I was just posting for clarity for those with a less technical inclination.
Yeah.. sorry you're right.
Some (me) tend to forget that ;)
03 Jan 2018 10:20 #188001 by mlines
Replied by mlines on topic Lift Kit shopping list
This is why I like the Trailmaster product, some design thought has gone into it. Other suppliers simply add 3" inches to the standard spring length and call it a 3" lift. This often results in lifts greater than advertised (ie. a 2" lift closer to 3") but the ride and longevity of the lift (springs sagging and bending) is affected.
I have the Trailmaster 3" springs on mine and I am very please with the ride. However I have a lot of weight on the front so it was not quite a 3" lift at the front and they do not do a Diesel spring in 3". I topped it up with a pair of spring spacers to level the car off.
Time to create page: 0.440 seconds
