Lift Kit shopping list
- Caelite
01 Jan 2018 20:40 - 02 Jan 2018 16:12 #187950
by Caelite
Lift Kit shopping list was created by Caelite
Hey Lads
I know from searching that this topic has been done before, but not so recently (last thread I found with details was from 2015).
Basically I have a 2006 VVT+ Jimny, with the big front bumper, I want to fit a set of 215/75r15 BFG KO2s on 15x7 ET-15 Jimnybits modulars. Going for the -15 as it maintains the same shock clearance as the stock 15x5.5s 205/70r15s, however in my mind will minimise the wheel bearing life and mud 'overspray' issues found with the ET-30 wheels. Not fully set on KO2s, but due to positive experiences I have had with them on my works trucks, they are my default go too choice unless an exceptional deal comes up. Same with the wheels, I know the JimnyBits ones are widely used on here, so I assume they are of adequate quality.
With that being said, I recognise I need a lift to make my tyre choice look 'natural' in the arch, and as my 110k mile old stock shocks are giving me the tell tail signs that they are cooked . So settling on a full suspension lift to kill 2 birds with 1 stone. That is where I am looking for some help, firstly, I am undecided as to whether I should go for a 3" lift, or stick to 2", as I am led to believe the 3"+ requires substantially more work to do correctly.
Secondly I am wondering if anyone can recommend a shock and spring setup, it is for predominantly road use, however, I will admit, I beat the living daylights out of my vehicles, it will be thrown into corners at the limit of front end grip, it will be rattled down gravel tracks at 90kph, etc etc. Basically I am looking for sure footedness, serviceability & longevity over comfort.
Finally, I am wondering if I am missing anything from my 'shopping list' of periphery to ensure optimal performance post lift, so far I have noted down:
0. Shocks & Springs, currently I am split between Jimnybits springs and Pro-comp ES1000 shocks, have experienced pro-comps in the past on Land Rovers & people speak highly of them for bang4buck, also looking at Trailmaster sports on Martins shop. The only other brand I know the green oval brigade enjoy is Old Man Emu but they don't seem to offer a Jimny lift in the UK.
1. Castor correction bushes
2. Rear shock relocation
3. Brake lines (ARBs will remain in position, any excuse to put some breaded steel lines in though)
4. Adjustable panhard rods
5. Driveshaft extension
6. Steering damper (not lift related, In my mind I think it would do much to improve the Jimnys road manners)
Any advice welcome, I have plenty of experience in the past lowering cars and setting track geometries, however this is my first foray into putting together a 4x4.
CAE
CAE
Last edit: 02 Jan 2018 16:12 by Caelite.
01 Jan 2018 22:25 #187954
by furo
Replied by furo on topic Lift Kit shopping list
I'm very far from an expert, but I've recently installed a 2" lift (trailmaster comfort) on my 2004 and just have a few points:
- When I first installed the lift I had 15x7.5" zero offset wheels and when I went to 215/75s they rubbed on the arch, this was completely resolved by going back to stock width wheels. I imagine the same thing would happen with 7" -15 wheels, especially as your bumper is bigger than mine. It was the outer edge of the tyres rubbing because they stuck out from the stock arches a little.
- I really like my trailmaster comfort lift, as it is much smoother than stock, but it does have a little more body roll so might not be ideal for your purposes. Having said that I don't think I have to drive it any slower than I did with stock suspension. I understand the procomps (and presumably the trailmaster sport) are much stiffer.
- The trailmaster kits include a brake line extension, so if you go for that you won't need to buy one separately. Having said that I don't believe an extended brake line is necessary for a 2" lift. Also note the trailmaster kit is far cheaper on this site than on other sites.
- I understand that driveshaft extensions and rear shock relocaters aren't necessary with a 2" lift (at least I certainly haven't done them).
Again, I'm very much a novice and don't pretend to be an expert! These are just some things I've found out while sorting my lift. All the best!
- Thank you received: 1915
02 Jan 2018 05:29 #187958
Replied by Lambert on topic Lift Kit shopping list
What you're asking from your jimny is quite difficult for it to achieve. You are asking for big chunky tyres and a raised centre of gravity to be able to cope with high speed and cornering. First off the larger tyres will affect acceleration. Secondly chunky tyres will not offer the same road grip as smoother ones also raising the centre of gravity will ask even more of the tyres. Going for a stiffer suspension to eliminate the negative impact of the lift in turn detracts from the off road ability by removing compliance for lumps and bumps. What I am getting at is that it is a well established route to turn a Jimny into a very capable off roader, it is also possible though less common to go go cart like I have but it's essentially impossible to combine the two successfully.
- TomDK
02 Jan 2018 08:55 #187960
by TomDK
Replied by TomDK on topic Lift Kit shopping list
I'd definitely get the Trail Master "2 sport kit with that you mention. Probably the diesel springs when you have a heavy front bumper.
No reason for rear shock relocation brackets. A waste of money a best, worst case you bottom out your shocks damaging them.
Old Man Emu shocks are also available for any vehicle from ARB dealers. Also great quality shocks and springs.
02 Jan 2018 10:13 #187962
by Busta
Replied by Busta on topic Lift Kit shopping list
To throw another option into the mix- fit the 215/75r15s on your standard rims (they will fit without any lift) and leave it at that. You retain the standard handling, which is a great compromise between road comfort and off-road ability, and you save money for things that will actually make it a better car, like an engine conversion or locking diffs.
02 Jan 2018 12:50 - 02 Jan 2018 12:54 #187965
by furo
Busta's solution seems like it might be the best for your purposes!
When my original shocks and springs were tired I replaced them with stock springs and Munro 4x4 shocks. These dramatically improved the handling but it's obviously impossible to tell whether that's because of how good the new bits were or how buggered the old stuff was. In the end I regretted not having gone straight for the lift kit, but it sounds like I drive a lot slower than you lol.
I've sold the Munro shocks, but haven't been able to sell the stock height springs so you could have them for free if you decide to go that route. I'd recommend changing both because when I did mine a couple of the original springs had cracks in them.
I guess it makes sense to get the tyres first and see what you think of the handling and look. Then you can either go for replacement shocks and springs or a lift kit.
Last edit: 02 Jan 2018 12:54 by furo.
