She's alive!
19 Nov 2017 21:37 #186476 by Rhinoman
Replied by Rhinoman on topic She's alive!
mlines wrote: its just as if it was supposed to idle at that speed.
Its possible but you'd need a Suzuki scan tool to check the target idle.
The following user(s) said Thank You: mlines
19 Nov 2017 22:05 #186478 by mlines
Replied by mlines on topic Re:RE: She's alive!
I will wait until I have a new lambda sensor in, it was idling ok today for some reason
Sent from my Nexus 6P using Tapatalk
20 Nov 2017 10:48 #186501 by Busta
Replied by Busta on topic She's alive!
Great video. The engineering in modern Japanese engines never fails to impress me.
  • helijohn
20 Nov 2017 18:03 #186526 by helijohn
Replied by helijohn on topic She's alive!
Busta wrote: Great video. The engineering in modern Japanese engines never fails to impress me.
My Celerio is a prime example.
21 Nov 2017 08:04 #186540 by kirkynut
Replied by kirkynut on topic She's alive!
Hurrah!
I did think it would sort its self out but through use, not sleep. It's had enough sleep!
Just make the journey to the MOT station a long one to get the exhaust nice and hot and to evaporate all that moisture sat in it and I reckon it will be fine. Testing the coolant will settle your mind but I've only heard of one twin cam head gasket having let go. You read more than I do though.
Do part the back box from the exhaust and see what pours out though as I've found that's where a lot of the moisture collects. Mine has dripped from there before being re-sealed for the MOT but the moisture means it's needed sealing twice now. New bolts and some exhaust paste will be needed though.
  • helijohn
21 Nov 2017 09:02 #186542 by helijohn
kirkynut wrote: Do part the back box from the exhaust and see what pours out though as I've found that's where a lot of the moisture collects. Mine has dripped from there before being re-sealed for the MOT but the moisture means it's needed sealing twice now.
This is an interesting couple of sentences. Do you go to the trouble of disconnecting the box?
Time to create page: 0.211 seconds
