She's alive!
21 Nov 2017 21:39 #186570 by kirkynut
Replied by kirkynut on topic She's alive!
When the exhaust has been leaking gasses through the joint I've had no option but to disconnect them to re-seal them John. You can poor a little water out of the back box from where it draws it in as condensation as the back box cools.
I had a K11 Nissan Micra a few years back and the back box on that actually had a drain hole in It! This gave it longevity and as it was designed into it would not cause an MOT failure.
  • helijohn
21 Nov 2017 21:52 #186571 by helijohn
Replied by helijohn on topic She's alive!
kirkynut wrote: When the exhaust has been leaking gasses through the joint I've had no option but to disconnect them to re-seal them John. You can poor a little water out of the back box from where it draws it in as condensation as the back box cools.
My Junior stands a lot - a very lot and I am always concerned about the water in the box but to get it off would be a real game. Could a hole be drilled and a self tapper put in to use as a drain hole. Where was your drain hole on the K11 Rob?
22 Nov 2017 08:39 #186582 by kirkynut
I think you'd cause rust John as they're coated, either galvanised or something else and you'll leave it bare at the point it's most damp.
  • helijohn
22 Nov 2017 11:07 #186590 by helijohn
kirkynut wrote: I think you'd cause rust John as they're coated, either galvanised or something else and you'll leave it bare at the point it's most damp.
Good point. I need a SS exhaust.;)
Regarding my Celerio, I was told somewhere by someone that today's exhausts are made to last longer. I wonder.
22 Nov 2017 11:46 #186592 by Lambert
Replied by Lambert on topic She's alive!
The one on Ermintrude is coming up 7 year old and whilst the back box outer shell is not a pretty sight it doesn't yet leak. Zebedee on the other hand with a third of the milage in ten less months on the road is noticeably more crusty for most of the length of the exhaust but again not currently leaking.
  • petejones69
22 Nov 2017 13:33 #186596 by petejones69
Replied by petejones69 on topic She's alive!
Nice choice in vehicle names B)
