Winch Recommendation
  • TomDK
29 Oct 2014 21:19 #127888 by TomDK
Replied by TomDK on topic Re:Re: Winch Recommendation
kirkynut wrote: Oh No! Not the "What's the best winch argument?" again!
Dyl, a steel rope will be fine for what you want for some time as long as you take the right safety precautions, such as wearing good thick leather gloves to handle it, using a winch blanket and making sure everyone stands clear in case it snaps.
Having said that, synthetic rope is safer and having been near many a winch rope snapping I can tell you that they don't flail around like a wire rope and just recoil a bit in the line of the pull. Having been hit in the leg by one of these ropes I can assure you it did not have enough energy to hurt me. That had the full weight of a Land Rover 90 tray back on it.
Super Winch are a premium brand to an extent. So if you buy a Super Winch with their own rope on, you can be sure it's not rubbish.
For Green Laning you ought not need a winch, however, things happen. You'll barely ever use it. It's a get out of jail card, so why spend a fortune.
You need to think about what you are going to winch off of. There's unlikely to be a tree, so some type of ground anchor would be a good idea to carry. Pin types are light and don't take up as much space.
There's my point of view and 2 penneth worth.
Just like all the tyre vs lift questions :)
Remember that Super Winch winches are made in China as well as all other winches in that price range. Also the aforementioned Super Winch model is one of their budget winches. You can be sure that the synthetic rope on it is only a cheap Chinese rope. The pricetag says it all.
29 Oct 2014 22:34 #127903 by kirkynut
I've no problem with answering repeat questions Tom. It's this same argument about which winch is best where no one wants to give an inch or see the other person's point of view that keeps repeating its self I get bored of.
You are one of the main suspects in this refusing to see others points of view in as much as you won't accept that not everyone will find a Goodwinch the best winch for them. People don't all want a premium brand winch at a relatively high price when they may never use it.
Anyway, Goodwinches are just re branded Kingone winches with a bit of silicone sealant. They are made in China too. They are good quality but not all of the other Chinese winches are rubbish, which people have told you time after time from owning them themselves.
I try to give balanced advice according to people's needs from my experience, which is good on this subject as I've known people using most makes and models of winches in competition and seen the problems they experience.
Perhaps we could all just have a bit more of an open mind. I mean do you really think the synthetic rope on a Super Winch is going to be a load of rubbish? Not as good as Bow Rope perhaps but not bad though eh!
  • jonesyba420
29 Oct 2014 23:44 #127904 by jonesyba420
Replied by jonesyba420 on topic Winch Recommendation
Dare i say it............................................
For greenlaning a spade and waffle boards are probably more usefull.
30 Oct 2014 07:14 #127906 by kirkynut
Replied by kirkynut on topic Winch Recommendation
jonesyba420 wrote: Dare i say it............................................
You are probably right there dear Sir, strapped to roof bars.
  • Reloaded
30 Oct 2014 07:26 - 30 Oct 2014 07:31 #127908 by Reloaded
Replied by Reloaded on topic Winch Recommendation
I carry a spade and waffle boards, but it depends on terrain I guess. The areas local to me - the Yorkshire Dales, North York Moors and the Lakes are predominantly very rocky - so the spade has never been used in anger apart from in the snow. Waffle boards can come in handy, but on hard surfaces the vehicle being recovered tends to just fire them out from the under the wheels rather than going forward.
The quickest, no-fuss way to get a vehicle on its way is to strap it to another truck and give it a helping hand - an extension of this approach is your winch - you won't use it often when laning, but on occasion it's the quickest way of getting the group going again without any drama.
It's worth having as much recovery gear as is reasonably possible (and the knowledge of how to use it) - straps and shackles are your main friends and they are relatively inexpensive. A winch is an expensive addition to your recovery arsenal , but when that times comes when you need to use it, you'll be glad you have it although, as long as you're not daft enough to go out on your own, you'll get out of most situations with the help of another truck.
Last edit: 30 Oct 2014 07:31 by Reloaded. Reason: fudge packer
  • gaz3359
30 Oct 2014 07:44 #127911 by gaz3359
Replied by gaz3359 on topic Winch Recommendation
Ive had a winch fitted for 15 months now and can say in that time I bet it hasn't been used 10 times, im a regular greenlaner and most know my jimny is done on a budget, I wanted a winch as a last resort sort of thing and I like them, I run a superwinch thati got 2nd hand for £150 it had just been refurbished and was in good order it's got a synthetic rope fitted alot lighter than the steel and the winch is only rated for 6000.for what I do for me it does the job spot on ive pulled out a terrano in a tight spot before and managed no problem.most bases have been covered in this topic, id love a more expensive winch if money was no object for me.just my experiences and 2 pence worth
