engine replaced and exhaust red hot
  • Dave cc
28 Apr 2014 21:49 #113642 by Dave cc
Replied by Dave cc on topic engine replaced and exhaust red hot
freedacall wrote: Running very low on power, has this rattling noise, Im wondering if something was not connected when
i put all the harness together. the engine sounds better than old one generally quitter.
Here is a picture of the exhaust, looked into the cat it seems like its there can only see it from the sensor hole.
never seen anything like that before :sick:
  • freedacall
29 Apr 2014 07:21 #113667 by freedacall
Replied by freedacall on topic engine replaced and exhaust red hot
We are near Brecon, spoke to the guy who i bought the engine from he ran me through a series of tests to see if its the lamda sensor, or something, nothing changed.
I guess I can always take the engine out and get a refund a,d slot another in, its a two day thing but kind of feeling
tired of trying to figure it out.
There is only one cat on this model the middle one I guess it is totally cooked now.
It got red hot like that from driving 2 minutes up and down out track.
its scary, makes you wonder what happens if you drive for 10 minutes, maybe it will turn into a jet engine.
could be a special model with extra boost :lol:
29 Apr 2014 11:35 #113682 by Busta
I can't see how it would be getting hot on the downwind side of the cat unless there is a blockage further along. Has your back box collapsed? Try it without the back box on. It will be noisy but you'll soon see if it runs better. Or becomes an epic flamethrower...
Why did you have to replace the engine in the first place?
The following user(s) said Thank You: freedacall
  • markyp2000
29 Apr 2014 17:03 #113699 by markyp2000
Replied by markyp2000 on topic engine replaced and exhaust red hot
AS IV SAID UNBOLT THE JOINT AFTER THE CAT AND SEE HOW YOU GET ON BECAUSE THE REST OF THE EXHAUST MAY BE BLOCKED CAUSEING BACK PRESURE
  • freedacall
01 May 2014 09:19 #113862 by freedacall
Ok boys and girls here is the report, when I put the new engine back in, i knocked the coil pack electrical connector some, so when I plugged it in it was not engaging properly, only 3 injectors where working properly, the extra fuel
is dumped into the exhaust and hence the jet engine effect.
The engine is now good, the exhaust is good except that it failed its emission test probably due to the fact that the cat has overheated.
The bad news (or good) is that the reason i changed the engine in the first place was because the water was boiling out,
which I thought was a head gasket, but turned out that new engine does the same........
Due to radiator cap missing a spring.
So much toil for one little part, I have ordered a new one, that should sort all the problems, The engine is 60k less than older one so i guess some good came out of it.
  • Yellostreak
01 May 2014 09:29 #113864 by Yellostreak
Replied by Yellostreak on topic engine replaced and exhaust red hot
Good news in a way.. glad its on the road to recovery!
Time to create page: 0.164 seconds
