engine replaced and exhaust red hot
- freedacall
27 Apr 2014 13:09 #113470
by freedacall
Replied by freedacall on topic engine replaced and exhaust red hot
Thanks guys, this is the m13a dohc engine, it has two lumps so i guess two cats (miaow) truth is
that it glowed red hot in two spots, one after the first one and one before the scone, maybe
the cat broke on delivery to me (engine was).
and messed up the second one (brand new) hopefully you are all right I can take the first of the old engine and replace
to the new with the lambda sensor, and if I'm lucky (sometimes am) than I can still save the second one too.
I was worried because you know you put an unknown engine in and you kind of expect weird things to happen,
its the right engine and all the harness bits meet properly, but there are some many little things you think, what may happen if you missed one (don't think I did).
I will report once i get a moment to sort it out, is it safe to drive without the honey comb mesh, I mean I know it may smell some but can it harm anything, mot is long due....
Thanks for all the replies, And thanks for ray too, which have be a life saver with getting our suspension sorted earlier this year.
- markyp2000
27 Apr 2014 17:01 #113494
by markyp2000
its a twin cam it dont have a belt its a chain engine
Replied by markyp2000 on topic engine replaced and exhaust red hot
Flameboi201 wrote: Cambelt a tooth out and running lean is my geuss mate . Did you replace the belt before u fitted the engine ?
- Dave cc
27 Apr 2014 17:37 #113501
by Dave cc
Replied by Dave cc on topic engine replaced and exhaust red hot
shittin hell if its running that lean think engine would have melted by now :sick:
- Dave cc
27 Apr 2014 18:24 #113504
by Dave cc
Cant for the life of me think what can be making manifold get that hot unless there is some ridiculous amount of unburnt fuel getting into it and burning but that fuel would have to have passed accross the cylinders and if that much engine just wouldnt run
- freedacall
28 Apr 2014 17:05 #113589
by freedacall
hi. and thanks for all the help. it is still hot after changing both cats so .....?
- Yellostreak
28 Apr 2014 17:23 #113593
by Yellostreak
Replied by Yellostreak on topic engine replaced and exhaust red hot
daft question this but apart from the cats glowing red does the thing run OK or is it coughing and spluttering, low on power or anything?
if its running fine then its a real curios one since any of the possibles already mentioned would cause it to run rough
even though there is a chain its still possible to get it a tooth out on one or both cams.. if timing is wrong then fuel could be igniting inside the exhaust and the first victim is likely to be the cat..
but again it would be running rough.. Or you have a TURBO
