engine replaced and exhaust red hot
  • freedacall
28 Apr 2014 18:49 #113613 by freedacall
Replied by freedacall on topic engine replaced and exhaust red hot
Running very low on power, has this rattling noise, Im wondering if something was not connected when
i put all the harness together. the engine sounds better than old one generally quitter.
Here is a picture of the exhaust, looked into the cat it seems like its there can only see it from the sensor hole.
  • jonesyba420
28 Apr 2014 18:59 #113616 by jonesyba420
Replied by jonesyba420 on topic engine replaced and exhaust red hot
If you shake the cat does it rattle?
  • Yellostreak
28 Apr 2014 19:57 #113620 by Yellostreak
Replied by Yellostreak on topic engine replaced and exhaust red hot
if it has new cats then it should not really rattle.. plus the big thing that has changed is the engine..
sounds to me like the engine is not happy.. maybe the timing on the chain is wrong.. maybe there is damage to a valve... really the cat would only ever get that hot if there was combustion taking place in the exhaust so sounds reasonable to think that fuel is not getting burnt when all the valves are shut..
sad fact is if this is the case could be that the cats are knackered too as they are not built to be burnt!..
  • markyp2000
28 Apr 2014 20:32 #113623 by markyp2000
Replied by markyp2000 on topic engine replaced and exhaust red hot
Unbolt the center pipe from the cat and see if it glows as it may be the other part of the exhaust blocked have you put you hand over the tail pipe to see if a lot of gases is flowing out
28 Apr 2014 21:18 #113634 by Rhinoman
Have you checked the spark plugs? if its pouring fuel through then they will be very wet and sooty. Have you got any fault codes, last time I looked at an M13 with a blocked cat it was throwing a bunch of codes, including MAP and IAT.
  • markyp2000
28 Apr 2014 21:32 #113639 by markyp2000
Where are you located as it dont say in your profile there may be some one close to you that can help
Time to create page: 2.663 seconds
