215 75 tyres on 7x15 rims
  • helijohn
14 Sep 2013 07:25 #83113 by helijohn
Replied by helijohn on topic 215 75 tyres on 7x15 rims
jonesyba420 wrote: Lose the chrome s on the front,merely stuck on with double sided tape.
Thanks Alex. Do you know how the Jimny sign is held on at the back?
  • jonesyba420
14 Sep 2013 15:40 #83143 by jonesyba420
Replied by jonesyba420 on topic 215 75 tyres on 7x15 rims
Generally speaking most manufactures stick them on with double sided foam tape so they should pull off with some persuation.might need to use a flat bladed screw driver with a rag wrapped on the end to protect the paint to get them going. There will be years of grime around the letters so get yourself some t cut and be prepared to spend along time cleaning!
ive been thinking about just hand painting mine gloss black.
  • helijohn
14 Sep 2013 16:13 #83144 by helijohn
jonesyba420 wrote: Generally speaking most manufactures stick them on with double sided foam tape so they should pull off with some persuation.might need to use a flat bladed screw driver with a rag wrapped on the end to protect the paint to get them going. There will be years of grime around the letters so get yourself some t cut and be prepared to spend along time cleaning!
As long as it is not rivetted on or just a popper fit I usually get some strong twine and see saw the twine behind it. Worst is when the motor has had a respray and you find a layer of paint missing when it is off. :blink:
  • Tadpole
14 Sep 2013 17:52 #83160 by Tadpole
Replied by Tadpole on topic 215 75 tyres on 7x15 rims
Try a Hair Drier first, get it nice & warm should just peel off then clean up with meths/petrol, t-cut etc ...... ;)
  • helijohn
14 Sep 2013 18:23 #83163 by helijohn
Thanks, I was going to use heat especially now the weather is sh-one-t as I want it off without bending it in case I want to replace it (which never happens lol). ;)
  • jonesyba420
14 Sep 2013 18:49 #83168 by jonesyba420
Im 99% positive there just stuck on john. French cars are often riveted/poppered on but I dont think thats the case with the jimny. Keep us posred as i may do this to, think theyd look good black tho.
Time to create page: 0.295 seconds
