Alternative Antenna
- Thank you received: 479
But first things first, I will check out the wires/connections at the base of my antenna.
- Max Headroom
- Banned
- Thank you received: 217
- Thank you received: 333
Works great.
Looks like three wires on one connector, an aftermarket replacement might be a problem unless the new wires are run to the head unit?
Not sure how the surround comes off the screen to try and get a look at the connectors at the back of the head unit?
- TaterTot
- Visitor
TaterTot wrote: Is it 3 wires from the antenna base, to the white connector there? I can't really imagine anything else.
Yes exactly that, shadow from the flash makes it look like more wires.
- TaterTot
- Visitor
TaterTot wrote: As expected really. Then you are back to finding a 1/2 length antenna (1/2 of whats there today).
Damn!
Thanks for all your input though really appreciate it
- TaterTot
- Visitor
How stiff are the antenna that is there today, really?
I am thinking if I buy this Swivel base aerial and use a separate GPS antenna. I hope that with the adaptors they sell I will be able to connect the replacement aerial to the connector in the roof lining. Still need to do a bit of digging.
- TaterTot
- Visitor
Or you need to chop cables, and join them manually. As mentioned before, it might not be fantastic fun.
Glad to see you have progress
