Re:Re:Re:Will fitting rear freewheel hubs to my Gen 4 Jimny allow me to flat tow the vehicle
13 Nov 2021 20:59 #240082
Replied by mlines on topic Re:Re:Re:Will fitting rear freewheel hubs to my Gen 4 Jimny allow me to flat tow the vehicle
I see what you are saying but the duty cycle of forward drive to reverse/engine braking is much higher in favour of forward drive. Reverse and engine braking are low energy and less frequent.
But as I said I have no evidence it is true, was just told it
Sent from my moto g31(w) using Tapatalk
- lookonimages
- Thank you received: 72
14 Nov 2021 08:10 #240088
by lookonimages
Replied by lookonimages on topic Re:Re:Re:Will fitting rear freewheel hubs to my Gen 4 Jimny allow me to flat tow the vehicle
it is not the diffs that is the issue. the SA 4x4 forum has discussed this many many times. it is transfer case that can be the problem. Both transfer case and main gearbox back driven in neutral can be damaged due to lack of lubrication.
only real way to limit damage is to take off prop shaftt.
free floating will not adress the issue, of flat towing. this issue only started really with gen 3.
The following user(s) said Thank You: mlines
- Thank you received: 1992
14 Nov 2021 08:19 #240089
Replied by Lambert on topic Re:Re:Re:Will fitting rear freewheel hubs to my Gen 4 Jimny allow me to flat tow the vehicle
This is why I would sooner use a trailer than flat tow, it also means having a meaningful braking system instead of having to bodge the vehicle brakes and also having to custom build some kind of A frame. A trailer is just simpler.
- Roger Fairclough
- Thank you received: 225
14 Nov 2021 09:34 - 14 Nov 2021 09:37 #240092
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Re:Re:Will fitting rear freewheel hubs to my Gen 4 Jimny allow me to flat tow the vehicle
I fully agree that "bodging" the braking system is a big no-no in any situation but surely you need to know how a person set up the system before a claim can be made that it was bodged ?
Roger
Roger
Last edit: 14 Nov 2021 09:37 by Roger Fairclough.
- Roger Fairclough
14 Nov 2021 09:42 #240093
by Roger Fairclough
If you turn the half shaft from a wheel you turn the diff. and that churns up the oil and everything gets lubricated. Why then if you turn the propshaft which turns the T-box will you have a problem re: lubrication as the gears in the box will be churning around in oil?
Ditto the main box, manual of course.
Roger.
Roger.
14 Nov 2021 09:58 #240094
Replied by mlines on topic Re:Re:Re:Re:Will fitting rear freewheel hubs to my Gen 4 Jimny allow me to flat tow the vehicle
I would assume that the gear rotation along with the case casting are designed to pickup and splash oil around in the forward direction of motion and not the reverse direction of motion. There are certainly casting shapes around the gears where they fit into the case
Time to create page: 0.223 seconds
