Already 2” Springs?
- Dirtbird
14 Sep 2021 12:46 #238600
by Dirtbird
Replied by Dirtbird on topic Already 2” Springs?
Sean your better off, you know what your buying and you will be safe on and off the road
- Sean65
14 Sep 2021 13:18 #238606
by Sean65
Replied by Sean65 on topic Already 2” Springs?
I think you are probably right on reflection
would I still put the rubber mounts at the top of the spring? I guess these act as a softer mount surface and also acts as a sort of dislocation cone.
14 Sep 2021 14:50 #238607
Replied by jackonlyjack on topic Already 2” Springs?
Yes fit the rubber seats there should be 4
Rears look a little like dislocation cones
Fronts look like the cone point has been cut off
sell the spacer
sell the spacer
- Sean65
14 Sep 2021 17:32 #238610
by Sean65
Exactly my plan
the rear is back together. I just need to get some washers to fit either side of the lower damper mounts. I assume there should be some
too wet to redo the fronts tonight.
- Dirtbird
14 Sep 2021 21:25 #238616
by Dirtbird
stick up a few pictures of your project. Tip for you sean. Disconnect the front shock absorbers from the bottom on the front then jack up the body from the chassis makes swapping the springs soooooo much easier . Do the same for the rear.
- Sean65
15 Sep 2021 05:24 #238619
by Sean65
Thanks. I dd that when I put the spacers in the front last week It helped to just remove the calipers too. At least it has all been apart so there should be no issues.
Hmm! A project. Almost. It set off as something just to jump in and go while my 90 is off the road but I guess it is heading more that way.
Time to create page: 0.196 seconds
