Already 2” Springs?
- Sean65
11 Sep 2021 15:16 #238475
by Sean65
Already 2” Springs? was created by Sean65
Hi. I have just received some new rear damper and was going to fit the spring spacers as per the front. However, on taking the springs off there was no home made spring spacer as I found at the front and the springs are 35 cm. can i take it these rear springs are already for a 2” lift so do not need the spacers. Cheers
- Dirtbird
11 Sep 2021 18:52 #238480
by Dirtbird
Replied by Dirtbird on topic Already 2” Springs?
Can you post some pictures Please Sean65
- Sean65
11 Sep 2021 20:29 #238491
by Sean65
Replied by Sean65 on topic Already 2” Springs?
Can fo but of what else exactly. The spring is 35 cm. I just don't know if they are the standard or already 2” lift
- Dirtbird
11 Sep 2021 21:01 #238493
by Dirtbird
Take some pictures of the springs and the spacers. If you can put the springs together in a line so we can look at them.
- Thank you received: 1996
12 Sep 2021 04:57 #238498
Replied by Lambert on topic Already 2” Springs?
It could be that the springs you have in the back are actually front axle springs as they can lift the back upto 40mm ish.
- Sean65
12 Sep 2021 06:29 #238504
by Sean65
Ok. Here goes. The one on the left is as they came off. The one on the right is what I thought would simply go back on. However, the diameter of the top of the spring is too small for the spacer to fit into.
puzzling.
puzzling.
