Rear gearbox oil seal
  • Danparry
07 Sep 2021 11:33 #238313 by Danparry
Replied by Danparry on topic Rear gearbox oil seal
OK thanks heaps,
I hope it all works for me lol
Also with the epoxy would jb weld be OK or dynagrip dynasteel work fine?
07 Sep 2021 20:06 #238323 by jackonlyjack
Replied by jackonlyjack on topic Rear gearbox oil seal
If it's leaking from the prop cap the seal is possibly ok
So seal the cap and see if it stops leaking
  • Dirtbird
07 Sep 2021 20:11 #238324 by Dirtbird
Replied by Dirtbird on topic Rear gearbox oil seal
Have a look at this.
www.bigjimny.com/mediawiki/index.php/Gea...put_end_oil_leak_fix
Might just do that while I can...
  • Danparry
08 Sep 2021 05:54 #238328 by Danparry
Yeah I'll have a look tonight.
I noticed it's shakey a little now at low rev/idle I think the gear oil may be low :(
I'll have do top it up tonight and take a look
  • Danparry
08 Sep 2021 09:46 #238338 by Danparry
So i just got home from work and checked the gearbox oil,
it was fine thank God for that
It only took one pump of my oil filler and oil started running out, so I'm stoked about that
Still waiting for my oil seal to arrive in the post,
Also I bought some of this epoxy today to use to fill on the shaft,
Would this be fine?? It says it's used in high heat areas,
Engine blocks, bbqs mufflers ect
  • Danparry
15 Sep 2021 06:34 #238620 by Danparry
I received my oil seal today, the post has been very slow lately,
just a question would I be right to assume that the side of the seal with the lip goes into the gearbox and the flat side faces out towards  the propshaft?
also do I just grease the entire seal up before installing it aswell??
I've got some pics there of the seal
