Re:Re:Re:Re:Re:Transfer case info
10 Mar 2021 09:59 #233602 by Old Neil
X8GGY wrote: Hi, No...
The auto transfer box has the same high ratio side, and the low side is lower as you originally thought...
BUT it is a switched model, not a stick shift one...
I'm trying to find out whether the gears inside would be transferable from the auto's transfer box to a manual transfer box, and have asked a friend who breaks the odd Jimny whether he has an auto one, as this may prove ideal for The Boogie to give me a lower gears offroad...
B)
Dave that is exactly the info i was looking for is there a way of finding the part numbers of the low raitio gears, see if i can buy them new do you know if i can fit them to my original transfer case
Cheers Neil
  • X8GGY
10 Mar 2021 14:44 #233608 by X8GGY
Replied by X8GGY on topic Re:Re:Re:Re:Transfer case info
Not sure whether the gears would be interchangeable Neil :(
Martin could probably provide part numbers if you ask him nicely...
If you asked him really nicely if you had a list of the gear part numbers in each box you could see if the rest of them were common / the same...
I myself will keep an eye on eBay just incase one pops up... ;)
10 Mar 2021 15:29 #233612 by Old Neil
X8GGY wrote: Not sure whether the gears would be interchangeable Neil :(
Yeah I'm thinking the same ,with the reduction gear set's they state you have specify one or the other parts aren't interchangeable
What's the call Sir Martin, the keeper of the knowledge
10 Mar 2021 16:23 #233617 by mlines
The following parts change between the manual and automatic.
Part 8 - Chain
Part 7 - Input shaft
Part 10 - Output Gearset
Part 3 - Front Drive Clutch - lots of different thicknesses
The following user(s) said Thank You: X8GGY, Old Neil
  • X8GGY
10 Mar 2021 16:39 #233619 by X8GGY
Replied by X8GGY on topic Re:Re:Re:Re:Re:Transfer case info
He's a good egg! Nice one Martin B)
10 Mar 2021 21:19 #233631 by Old Neil
Thanks Martin
Neil
Time to create page: 0.303 seconds
