Re:Re:Re:Re:Re:Transfer case info
10 Mar 2021 06:20 #233590
by Old Neil
I'm not going the big tyre lots bar work track, trying to keep it lite as possible
Replied by Old Neil on topic Re:Re:Transfer case info
Thanks Dave, I'm totally impressed with your project can't wait hear it used in angerX8GGY wrote: You could of course "just" change the diffs to lower the gearing and compensate for larger tyres -
Later diffs (final ratio) in an earlier Jim'
That's esactly what I've done with The Boogie -
As I'm running 16" GV alloy wheels with ~ 29" tyres...
- X8GGY
10 Mar 2021 07:02 #233592
Replied by X8GGY on topic Re:Re:Transfer case info
Hmmm, if you just want to lower the low ratio side of the box, the auto VVT transfer box would fit the bill (as the high side is the same ratio) BUT it's electric / button controlled... You'd have to see if the gears were transferable to a manual stick transfer box?
- Thank you received: 1999
10 Mar 2021 07:40 #233593
Replied by Lambert on topic Re:Re:Transfer case info
Would it be possible to take the whole assembly with the actuators and have it run off a simple switch without the control module? Don't know, I've never tried.
10 Mar 2021 07:59 #233594
by Old Neil
Replied by Old Neil on topic Re:Re:Re:Transfer case info
Hi Lambert
Sounds like i might be barking up the wrong tree zookbob is saying internal ratios of transfer case between manual and auto gearbox jimny's are the same i was also posts from this forum dating back to 2011 talking about auto transfer case and bigger tyres
- X8GGY
10 Mar 2021 08:26 #233596
Replied by X8GGY on topic Re:Re:Re:Transfer case info
Hi, No...
The auto transfer box has the same high ratio side, and the low side is lower as you originally thought...
BUT it is a switched model, not a stick shift one...
I'm trying to find out whether the gears inside would be transferable from the auto's transfer box to a manual transfer box, and have asked a friend who breaks the odd Jimny whether he has an auto one, as this may prove ideal for The Boogie to give me a lower gears offroad...
- X8GGY
10 Mar 2021 09:28 - 10 Mar 2021 09:29 #233598
No, friend who breaks Jimnys hasn't got one, and says they are sought after and so command a high price too
Last edit: 10 Mar 2021 09:29 by X8GGY.
Time to create page: 0.379 seconds
