reversing lights
  • little boghopper
04 Jan 2018 10:28 #188032 by little boghopper
Replied by little boghopper on topic reversing lights
kirkynut, i checked em with the VOM and they work ok, loghts work when shorted out too, what happens in the box to make them work anyone know? just had a box fitted , have they forgotten something?
  • CharlesS
07 Jan 2018 21:52 #188114 by CharlesS
Replied by CharlesS on topic reversing lights
I checked the FSM in Section 7A for the manual transmission and there does not appear to be anything that could be missing.
Have you tried to manually actuate the back up lights with the switch removed from the transmission and plugged in ?
  • little boghopper
08 Jan 2018 09:36 #188121 by little boghopper
charless, no i have tried the switch when its plugged in the wiring , ie connectors pushed together, i just tested the switch taken off the box, and shorted the other points in the connector on the car and the lights worked.. i,ll try it all clipped together then ....
i,ll have a think... good idea charles thanks.
  • little boghopper
14 Jan 2018 15:51 #188368 by little boghopper
i have taken the switch off for the third time, and all works from the switch up, ie pushing the small ball bearing the lights come on, put it in gearbox in doesnt??? i,m wondering if the small ball bearing isnt protruding enough? thats the only thing i can think of now. my plan b was to cut the wires from the switch and run it inside, and have a switch inside.then wire a spotlight on the roof running wires from the existing reversing lights, would this work ? where would be the best place to bring the wire inside ? anyone a good idea? up under gear stick or through with wiring loom? cheers Liam.
14 Jan 2018 16:32 #188371 by Lambert
Replied by Lambert on topic reversing lights
Err possible. Until very recently reverse lights were not part of the mot but according to my tester the most recent revisions that and fogs plus a few other little bits are becoming tested.
  • little boghopper
14 Jan 2018 17:56 #188385 by little boghopper
11/60, hummm need this sorting then
