Removing Jimny vacuum hub system?
19 Jan 2017 15:11 #177014 by mlines
Have you seen this information , it may help you google for the correct manual
I have not put it in the Wiki yet, I see Bosanek has created a table for this information but he has not filled it in.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
If there is anything specific you need to know from the manuals, just ask.
The following user(s) said Thank You: wilku
  • wilku
19 Jan 2017 15:48 #177015 by wilku
Replied by wilku on topic Removing Jimny vacuum hub system?
Oh - the filenames are there - maybe that's the way. because I do not recommend following any of the results from google for "SN415 Service Manual" or "SN415 Wiring Diagram" ;)
I've got now what I need. Thanks Martin!
Mraz - can you check the VIN of your car? (It would help me to choose the correct Wiring Diagram and give you more hints)
  • Mraz
19 Jan 2017 16:30 - 19 Jan 2017 16:55 #177017 by Mraz
Replied by Mraz on topic Removing Jimny vacuum hub system?
Believe it or not - it works! I've bridged the connector coming to the vacuum sensor and light stopped flashing, now I can use 2H, 4H and 4L. When I reconected the vacuum sensor 4WD light started flashing. Maybe my sensor is not working and rest of the system is OK but at the moment I don't really care, I'm just happy I can drive my Jimny :) For now. I just hope the car doesn't catch fire haha.
[img=http://s29.postimg.org/6cv8bq4fr/20170119_165107.jpg]
Last edit: 19 Jan 2017 16:55 by Mraz.
  • wilku
19 Jan 2017 18:16 #177028 by wilku
Congrats!
Test it for a while and let us know if it works - we can then expand our Wiki article.
  • Mraz
19 Jan 2017 18:35 #177032 by Mraz
I will. Tomorrow I'll solder a bridge to original connector so I can connect/discinnect on the go and make it look the part.
Is there any danger of this "fix" somehow messing with the 4WD controler?
This forum is full of great info, I'm glad I found it. Thank you guys! And I apologize for the lack of grammar, I rarely get a chance to use English.
  • wilku
20 Jan 2017 09:48 #177052 by wilku
I am not a native English speaker too, but Mraz, your English is perfectly fine.
As to dangers of the fix - I am not really sure - tell which switch exactly did you bridge (and what are the colors of the wires there - I'll then consult the wiring diagram.
Time to create page: 0.411 seconds
