Handbraking rear wheels individually?
- 1066Boy
26 Nov 2016 08:47 #174933
by 1066Boy
Got lots of practice with my old Hi-Lux, no difflock and a very light rear end. It was just the same with my KJA. :laugh:
Replied by 1066Boy on topic Handbraking rear wheels individually?
NickR wrote:
1066Boy - I have never actually tried using the handbrake while spinning a wheel! Seems so obvious now you mention it
Nick
- NickR
26 Nov 2016 10:05 #174935
by NickR
Replied by NickR on topic Handbraking rear wheels individually?
You can tell I am new to Suzukis as I had to google what a "KJA" was
Had a quick scan of the MOT manual. There are a few key phrases :
It must be:
"designed to prevent at least two wheels from turning"
"Hydraulic parking brakes as a sole means of operation are not acceptable"
and specifically has a section for extra brakes
"This inspection applies to all vehicles with a secondary brake operating mechanism in addition to, or in place of, the normal parking brake lever. "
MOT rejection reasons include
"the parking brake is not capable of being maintained in operation by direct mechanical action only"
"A parking brake lever or control inappropriately repaired or modified. "
and lots of catch-alls about condition, obstructing smooth action etc.
So, there will be a lot down to the individual opinion of the MoT tester, but I can't see that cable operation of one wheel is a no-no as long as it leaves the main system working. Extending the individual cables to separate fiddle levers, so the normal system is unaffected would be good, but that is in the massive grey area about obstructing the mechanism. A simpler system to clamp/block an individual cable so the handbrake only acts on the other wheel might be the way to go as it may be easier to demonstrate to an MOT inspector.
Food for thought in the winter months anyway
Nick
It must be:
Nick
- Thank you received: 683
26 Nov 2016 13:45 #174940
Replied by jackonlyjack on topic Handbraking rear wheels individually?
i would have thought it easier to use 2x motor bike front leavers
and tee into brake lines near to the wheels
Jack
Jack
26 Nov 2016 14:07 #174942
by facade
How would the normal footbrake work then?
Replied by facade on topic Handbraking rear wheels individually?
jackonlyjack wrote: i would have thought it easier to use 2x motor bike front leavers
Jack
26 Nov 2016 16:32 #174946
i'm no brake expert but wouldn't the pedal brake work just the same
because all your adding is 2 more reservoirs with a cylinder on each
Jack
Jack
- mickt
26 Nov 2016 17:45 #174947
by mickt
Replied by mickt on topic Handbraking rear wheels individually?
Perhaps a NRV in each main brake line up stream of the tee in?
Time to create page: 1.689 seconds
