Non use of 4 wheel drive.
02 Jan 2016 11:13 - 02 Jan 2016 11:16 #159525
by McVicar
Non use of 4 wheel drive. was created by McVicar
Hi all, and a Happy New Year.
I have owned my Jimny for a couple of months now and absolutely love it. We live in Somerset and have just sited our caravan on a site in Devon for 12 months. Because the lanes down there are so narrow and sometimes muddy we decided a Jimny would be the perfect vehicle for our weekends away. Now to my question, I have no intention of taking the Jimny offroad so will rarely, if at all, need to use the 4 wheel drive. Do I need to use the 4 wheel drive periodically to keep everything working or can I just forget it and it will work when (or if) I ever need it. Thanks.
P.S. It's a 2004 with stick, not button, for 4WD if that makes any difference.
Last edit: 02 Jan 2016 11:16 by McVicar.
02 Jan 2016 11:21 #159526
Replied by mlines on topic Non use of 4 wheel drive.
even though its "stick" it would be best to pop it in 4WD occasionally to check the vacuum system works. Otherwise the first time you use it it will fail.
02 Jan 2016 11:30 #159527
by Busta
Replied by Busta on topic Non use of 4 wheel drive.
Yes regular use seems to be best. I think a lot of people's problems with the 4wd system are due to it being used so infrequently.
02 Jan 2016 11:43 #159529
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Replied by Mike G on topic Non use of 4 wheel drive.
one of the problems I had with my jimny 4wd was that the solenoids that control the vacuum pressure had seized, probably due to infrequent use. I managed to get them moving with a bathing in plusgas/wd40.
02 Jan 2016 12:11 #159530
by McVicar
Replied by McVicar on topic Non use of 4 wheel drive.
Thanks for the replies. I thought that might be the case. Will have to find some suitable terrian to use it.
02 Jan 2016 12:28 #159531
by Mike G
You can prove your 4wd works when stationary. When you engage 4WD, you should hear the front hubs click in. when engaged, if you jack the front sides up whilst the jimny is in gear, each side of the front axle shouldn't move. Also, when you disengage, you can prove that both sides of the front axle have disengaged by moving freely. Last thing you want to do is get stuck in boggy ground with no 4wd (like I have).
Time to create page: 0.456 seconds
