Non use of 4 wheel drive.
02 Jan 2016 17:23 - 02 Jan 2016 17:28 #159543 by facade
Replied by facade on topic Re:Non use of 4 wheel drive.
Busta wrote: Just click it into 4wd for 100yds or so on a straight bit of road once in a while. No need to go out of your way to find some mud.
McVicar wrote: Thanks. I thought I'd read that might cause the transmission to wind up. Is that only if you use 4WD on firm ground for extended periods?
Only if the wheels try to rotate at different speeds, they won't if you stick to a straight line on a smooth level road and all the tyres have the same diameter (same tread, correct pressures)
Probably be good for the seals to rotate the shafts and splash a bit of oil around
If you are worried, do it on a gravel road, but don't drive through the gravel down the centre of a tarmaced road, or near the curb, as that is where all the screws & nails end up, and you will get a puncture. (This is the real reason you avoid cross hatching even though you can drive on the broken ones, most people think you can't so that bit of the road doesn't get swept by tyres to pick up the debris)
Last edit: 02 Jan 2016 17:28 by facade.
02 Jan 2016 17:41 #159546 by McVicar
Another top tip. Thanks to everyone for being so patient with a newbie. Class 1 HGV driver but never had a 4WD car.
Sent from my GT-N7100 using Tapatalk
