Jimny still overheating head gasket done ?
- Johntom
27 Oct 2015 18:36 #154610
by Johntom
Replied by Johntom on topic Jimny still overheating head gasket done ?
Ok thanks, it seems like that's the problem as the car didn't overheat until immediately after the liquid seal went in. Should I start with the 2 heater pipes into the matrix and would a blocked matrix stop the flow to the thermostat area ?
- gaz3359
28 Oct 2015 11:41 #154687
by gaz3359
Replied by gaz3359 on topic Jimny still overheating head gasket done ?
Its a start yes, it will more than likely be a smaller pipe that golf I did had one going to the side of the head that was blocked solid had to tske the pipe off and use a welding rod to bash it out then blasted it with brake cleaner and air.
- slew53
28 Oct 2015 17:51 #154722
by slew53
this was a 55,000 mile K series engine that instead of repairing k seal was used, this helped (along with the moron behind the wheel) to destroy the engine, I was lucky in that I had already rebuilt an engine and I replaced all the hoses , but to clean the heater matrix and under floor pipes I hooked up a central heating pump and really hot soapy water and left it pumping, some put a dish washer tablet in ( not sure what the effects of really caustic stuff is )
Could be worth taking the rad off and flushing through with a hose pipe
Did you replace the water pump?
Replied by slew53 on topic Jimny still overheating head gasket done ?
- Johntom
28 Oct 2015 17:58 - 28 Oct 2015 18:21 #154723
by Johntom
Hi the water pump was replaced about 6 months ago, I haven't looked in there since adding the steel seal though. I will get the hose pipe out on Friday and see what the flow through the engine and heater matrix are like?
Last edit: 28 Oct 2015 18:21 by Johntom.
- colin_y
30 Oct 2015 13:13 #154888
by colin_y
Replied by colin_y on topic Jimny still overheating head gasket done ?
I would disconnect the heater hoses from the matrix and then join them together with a piece of plumbing pipe and run the engine - therefore bypassing the blockage.
You have blocked the heater matrix by the sound of things and no circulation will mean it overheats and will blow up.
- Johntom
30 Oct 2015 14:25 #154892
by Johntom
Hi
I have just had the hose pipe to the bottom heater matrix pipe and flushed out some rubbish via the top pipe, so the matrix is now flowing clear. I also ran the pipe through the heater rubber hose into the engine and the water came out of the top heater/engine pipe and the radiator bottom outlet (top hose still connected to radiator). Wasn't expecting anything from the bottom hose due to the thermostat being closed. Just filling it up and will report back.
