Jimny still overheating head gasket done ?
- mickt
30 Oct 2015 15:41 #154900
by mickt
Replied by mickt on topic Jimny still overheating head gasket done ?
The rubbish might have been the stuff you poured in the rad!
- Johntom
30 Oct 2015 17:45 - 30 Oct 2015 17:47 #154906
by Johntom
Replied by Johntom on topic Jimny still overheating head gasket done ?
Hi
Seems ok now, the heat started to come through the vents much quicker and hotter from start up. I drove 3 times around the block and the temp needle stayed just below 1/2 on the gauge. The 2 heater matrix hoses are both a the same (hot) temperature but the bottom radiator hose is still cold, is that right ?
Also noticed a slight drop in revs when coming to a stop or reversing, tachometer seems to settle at 750rpm, is that too low?
Last edit: 30 Oct 2015 17:47 by Johntom.
01 Nov 2015 09:31 #155038
by kirkynut
Replied by kirkynut on topic Jimny still overheating head gasket done ?
750 rpm is right for idle speed and revs will drop when stopping due to the servo taking more vacuum but the ecu should sort it out.
All coolant hoses should feel hot eventually but the one after the rad ought to be a bit cooler obviously. It will be quite hot still.
- Johntom
05 Nov 2015 17:26 - 05 Nov 2015 17:27 #155443
by Johntom
I have taken the car on a 20 mile drive and the temp needle stayed at 1/2 way. However whilst waiting at traffic lights on the way home the needle started to claim to 3/4. It seemed to stay there until I moved off so on the drive I let the needle claim again to 3/4, when I revved the engine, the needle dropped back to 1/2 ? The bottom hose from the thermostat is more aired than hot (although it's new), could it be the thermostat or the viscous fan ?
Last edit: 05 Nov 2015 17:27 by Johntom.
- BigT
05 Nov 2015 17:32 #155446
by BigT
Replied by BigT on topic Jimny still overheating head gasket done ?
If there is a noticeable temperature drop onthe bottom hose its aa sure sign that the radiator core is blocked.
- Johntom
05 Nov 2015 17:52 #155453
by Johntom
Hi
The radiator is new along with the rest of the cooling system, just wondered if the fan wasn't spinning fast enough st idle?
Time to create page: 0.947 seconds
