4WD-LOW not engaging
02 Oct 2015 13:51 #152872 by gilburton
Replied by gilburton on topic 4WD-LOW not engaging
If this doesn't work you may have dislodged or damaged something??
NOTE the clutch has to be FULLY depressed !!
I started off high and worked my way down ever since :-)
  • bythelake
02 Oct 2015 14:06 - 02 Oct 2015 14:08 #152873 by bythelake
Replied by bythelake on topic 4WD-LOW not engaging
It doesn't look like it's damaged or missing something. Only the connection of wires (plug) was fixed.
I am doing the procedure of engaging 4wd-l correctly.
Last edit: 02 Oct 2015 14:08 by bythelake.
02 Oct 2015 19:13 #152879 by mlines
Replied by mlines on topic Re:4WD-LOW not engaging
I am sure I read somewhere there is a reset sequence as the actuators get out of sync
Sent from my Nexus 5 using Tapatalk
  • bythelake
03 Oct 2015 06:19 #152902 by bythelake
Replied by bythelake on topic Re:4WD-LOW not engaging
Ok, I didn't even know you can reset things like that. I will try to google it. If you recall it please let me know.
Big thanks!
  • Lazia23
03 Oct 2015 19:37 #152952 by Lazia23
Replied by Lazia23 on topic Re:4WD-LOW not engaging
you can reset he computer by simply disconnecting the battery. try that. I haven't had to deal with the electrical 4wd system on a jimny but on a modern shogun, my god is it a bastard. should really get a mechanic with a dealer level code scanner to have a look. he should be able to tell you whats wrong. This is why i have a older jimny, everything's mechanical :P
03 Oct 2015 20:01 #152955 by mlines
It's not a computer reset, its to get the motors into sync, I will see if I can find it
I think it was from our friends in oz
The following user(s) said Thank You: Lazia23
Time to create page: 0.532 seconds
