4WD-LOW not engaging
  • bythelake
05 Oct 2015 12:23 #153017 by bythelake
Replied by bythelake on topic Re:4WD-LOW not engaging
I still can't find it. Googled on auszookers.com and nothing about resetting.
Found a proper service manual but nothing about actuator reset in there. It only states: "If actuator does not work correctly, replace actuator assembly". I hope to avoid that. I will keep may fingers crossed for Martin's good memory and keep on searching myself.
05 Oct 2015 13:01 #153020 by mlines
Replied by mlines on topic Re:4WD-LOW not engaging
The only thing I can find is here which talks about a failed 4WD Low proximity switch
www.bigjimny.com/index.php/forum?view=to...default&limitstart=0
The manual also talks about the three limit detection switches in the transfer box that tell the system where it is. At a guess the "sync" process involves getting the ECU to think it is in 2WD high and then winding the motor to the same position.
Time to create page: 0.156 seconds
