Advice on this rust
  • emu88
19 Sep 2015 17:01 #152256 by emu88
Replied by emu88 on topic Advice on this rust
the_goshawker wrote: Hi mate,
it looks like how mine did, if you go into the build thread then into falconer special edition look a couple of pages in and you will see how i did.
Dont worry it aint that bad promise :) :) :)
Hi, thanks :) I see you just cut out the jack well though, is that cause repairing where it meets with the vertical rear sill is too hard/pricey?
Can I ask how much you paid in the end for the welding you had done? Yours only looked marginally less severe than mine is.
I am just thinking of using aluminium mesh and filler myself though.
19 Sep 2015 18:23 #152262 by Rhinoman
Replied by Rhinoman on topic Advice on this rust
You will need to cut out the rot and weld in new steel if you're close to a body, seat or seatbelt mount. You may as well do it all properly.
19 Sep 2015 19:12 #152275 by Keithy
Replied by Keithy on topic Advice on this rust
emu88 wrote: By the way the headlight areas are literally perfect so I'm lucky there!:
I wondered what used to be there on mine.....mines a "lightweight" :D
  • mickt
20 Sep 2015 18:12 #152298 by mickt
Replied by mickt on topic Advice on this rust
Have you checked the rear of that body front cross member. They can rot behind the wheel arch plastic cover.
  • GuardianAngel
20 Sep 2015 18:15 #152299 by GuardianAngel
Replied by GuardianAngel on topic Re:RE: Advice on this rust
I would probably get some seam sealer along those joints if it were mine. That way you will weather proof the joints and stop all the crap getting between the skins and rotting it from the inside out.
21 Sep 2015 17:31 #152338 by Johnniehec
Definitely needs welding. Gauze and filler will just prolong the agony for a short time and make it more expensive in the long run.
Time to create page: 2.123 seconds
