Better cooling for the Jimny?
25 Jun 2015 18:12 #146591 by facade
Tomhorntoad wrote: Jimny runs hot when driven for long distances at speed. I've had a water pump and coolant change and cleaned out the rad. But is there a upgrade or something I can do?
How did you clean out the rad?
When the tubes silt up and block , backflushing with the hosepipe won't clear them. The usual trick is to lose the coolant*, and fill up with dilute hydrochloric acid (muriatic acid/brick acid) then run it for a while. This will convert the silt into soluble chloride salts, and clean out any tube that water can flow through. It will gradually eat into the blockages and clear them given enough time.
It usually causes the tiny pinholes that were blocked by silt to spring a leak though, and I wouldn't let it go through the heater core.
*I think the acid reacts with some antifreeze
25 Jun 2015 21:24 #146601 by Basketcase
I'm a little intrigued by the 'locking of the fan'.....how do I do this?
25 Jun 2015 22:39 #146605 by facade
You don't need to, unless the viscous unit fails. If you must, people contrive something with cable ties.
with a cold engine switched off, try and turn the blades. They should rotate with some resistance.
If they spin freely, or there is play in the fanblades, then the viscous unit is shot, and you need another.
You should not need a fan when driving at 50mph as there should be more than enough airflow through the radiator, the fan is for when you are not moving at speed.
The most likely reason for overheating is the radiator is partially blocked (either externally with mud, or internally with silt), if the thernostat isn't stuck, and there are blades on the waterpump.
I suppose the oxygen sensor could be faulty, and the car is running too lean, but they normally fail and cause rich running.
  • Statey
26 Jun 2015 07:43 #146613 by Statey
Replied by Statey on topic Re:Better cooling for the Jimny?
I had the same problem radiator looked fine and was flowing when I cleaned it whoever it wasn't until I took it out I found that the radiator had a hole in it at some point and had been sealed by previous owner. Bought a new radiator off eBay about £40 and it fixed the issue. For £40 its worth it!
  • Tomhorntoad
26 Jun 2015 15:02 #146636 by Tomhorntoad
Replied by Tomhorntoad on topic Re:Better cooling for the Jimny?
I'm thinking I don't get much air flow with my arb bumper .... Also doesn't help
27 Jun 2015 14:40 #146698 by kirkynut
Tomhorntoad wrote: I'm thinking I don't get much air flow with my arb bumper .... Also doesn't help
The Aussies make the ARB bumper and don't have any issues with cooling in their heat so it won't be the bumper's fault.
I think test the fan as suggested above. If that's ok buy a new rad for what they cost and change the coolant a few times over with a strong mix to break down and clear out any silt from the engine its self.
Time to create page: 0.567 seconds
