Better cooling for the Jimny?
  • Tomhorntoad
22 Jun 2015 11:57 #146402 by Tomhorntoad
Better cooling for the Jimny? was created by Tomhorntoad
Jimny runs hot when driven for long distances at speed. I've had a water pump and coolant change and cleaned out the rad. But is there a upgrade or something I can do?
22 Jun 2015 12:51 #146410 by minibbb
Buy a red one
  • rexthecat
22 Jun 2015 13:59 #146412 by rexthecat
Replied by rexthecat on topic Better cooling for the Jimny?
If the rads in decent nic it shouldn't overheat, might me worth checking out the thermostat, maybe not fully opening? I've never come across an updated direct fit jimny rad, if there is guess someone here will know! Otherwise you could put an oil cooler on it. Ebay sell cheap universal ones, not sure how good they might be.
  • Tomhorntoad
22 Jun 2015 15:10 #146418 by Tomhorntoad
Replied by Tomhorntoad on topic Better cooling for the Jimny?
Cheers all a good thought. I'll tahe a gander at the thermo ... Pain in the ass because I've got a safari treck coming up
22 Jun 2015 18:01 #146435 by Busta
Replied by Busta on topic Better cooling for the Jimny?
They shouldn't overheat unless something isn't working as it should. Check the thermostat and change the temperature sensor and radiator cap. It won't be anything major.
22 Jun 2015 18:21 #146439 by jackonlyjack
When mine started running hot
Strangely enough it was down to
the rear silencer collapsed internally
Jack
Time to create page: 3.734 seconds
