Would a faulty gearbox mount cause stiff gear changes?
22 Feb 2015 16:57 #138813 by Busta
It's easy to check the mount if you can lay underneath the car - just try to lift the back of the gearbox. I found mine is gone but I don't have any symptoms other than the odd strange noise.
The following user(s) said Thank You: minibbb
22 Feb 2015 18:28 #138818 by minibbb
Thanks gents, have one on order from suzuki for £30 so will hopefully get it fitted Tuesday.
If it doesn't solve the gear change maybe a better gearbox oil would help?
22 Feb 2015 18:31 #138819 by jackonlyjack
22 Feb 2015 18:37 #138820 by minibbb
jackonlyjack wrote: mine felt better with new oil in
semi synthetic i used ;)
I'm guessing the garage changed the oil when they swapped out the clutch so maybe used the wrong sort.
Can you remember the brand you went for?
22 Feb 2015 18:48 #138821 by jackonlyjack
Can you remember the brand you went for?[/quote]
just a cheap one from motor factors
drive master gear oil :huh:
22 Feb 2015 19:18 #138826 by safari
apart from the mount it can also be that when u changed the clutch u tightened too much the lever , it sits on a small plastic bush that if u tighten it too much the gear becomes stiff .i would 1st undo the gearlever and see how it is sitting on this bush it should not be too tight it is very small and round and oil i have always used normal 80/90 with no problem .hope this helps ;)
if u worry u die if u dont worry u still die so why worry
Time to create page: 0.483 seconds
