Would a faulty gearbox mount cause stiff gear changes?
20 Feb 2015 19:35 #138609 by minibbb
As above please gents- when I had my clutch changed the mechanic mentioned the gearbox mount was worn. I've noticed recently sometimes I have nice smooth gear changes whereas other times it's stiff and unpleasant.
First and reverse can also be hard to select and I get the groan on pull away which is apparently indicative of a worn mount.
Any thoughts appreciated!
  • idiotmobil
20 Feb 2015 19:48 #138616 by idiotmobil
mine done that and reverse was hard to get fixed and all was sorted
20 Feb 2015 19:55 #138618 by minibbb
idiotmobil wrote: mine done that and reverse was hard to get fixed and all was sorted[/quote
Was that all the gears harder to engage mate?
Hopefully the new mount will fix it!
22 Feb 2015 12:27 #138784 by minibbb
Anyone else able to say whether this is the likely cause of poor gear changes?
  • mickt
22 Feb 2015 12:38 #138788 by mickt
I found my mounting apart when I removed the gearbox recently. I had only driven the car 9 miles or so from where I purchased it and the gear changes were normal. It could cause problems I guess but it is worth checking. If you can lift the rear of the box up until it hits the tunnel then more than likely it has gone. If you read one of my threads(G13bb engine queries) I have given the details of where and how much I paid for mine compared with the dealers.
22 Feb 2015 13:37 #138794 by jackonlyjack
mine went hard to find 1st and reverse
and box was vibrating on the tunnel
easy fix got mine from suzuki £31
The following user(s) said Thank You: minibbb
Time to create page: 0.172 seconds
