Would a faulty gearbox mount cause stiff gear changes?
  • NineCherries
28 Feb 2015 17:31 #139433 by NineCherries
How solid is the replacement? Might sound weird but I checked mine the other day (took it off an inspected it). It was intact but I thought it was a bit soft. I could move the gearbox about if I pushed it by hand but I don't know if that's normal or not.
01 Mar 2015 07:22 #139499 by Halford
minibbb wrote: ........ and I get the groan on pull away which is apparently indicative of a worn mount.
after changing the gearbox mount do you still get the groan on pull away ?
or has it cured it :huh:
I've heard that the noise associated with the mount is more of a buzz at higher revs (i.e. 4000 rpm in 1st gear) :unsure:
thanks
01 Mar 2015 13:44 #139520 by minibbb
Ninecherries- much more solid than the old one I removed! The old one was knackered and flexing a lot!
Halford- the groan seems to have stayed put! Maybe slightly improved but still there im afraid!
The following user(s) said Thank You: NineCherries
Time to create page: 0.154 seconds
