Would a faulty gearbox mount cause stiff gear changes?
22 Feb 2015 21:25 - 22 Feb 2015 21:26 #138854 by minibbb
safari wrote: apart from the mount it can also be that when u changed the clutch u tightened too much the lever , it sits on a small plastic bush that if u tighten it too much the gear becomes stiff .i would 1st undo the gearlever and see how it is sitting on this bush it should not be too tight it is very small and round and oil i have always used normal 80/90 with no problem .hope this helps ;)
Thanks matey, is that to take off the gear-lever from above? The garage did the clutch change but I think the gear change is stiffer now it's been done.
Last edit: 22 Feb 2015 21:26 by minibbb.
23 Feb 2015 05:10 #138868 by safari
yes it is from the inside of the car it has this bush since it is with links and not sitting streight to the gearbox
if u worry u die if u dont worry u still die so why worry
  • mickt
23 Feb 2015 10:09 #138877 by mickt
Further the plastic bush. It seats right into the linkage and is shaped to take the ball end of the stick. If you are not aware that it is there it can be dislodged and as previous overtightened. You could have saved yourself £20 by ordering from Estonia. It is the original item!
23 Feb 2015 11:25 #138884 by safari
mickt wrote: Further the plastic bush. It seats right into the linkage and is shaped to take the ball end of the stick. If you are not aware that it is there it can be dislodged and as previous overtightened. You could have saved yourself £20 by ordering from Estonia. It is the original item!
have u got a link for the mount pls
  • mickt
23 Feb 2015 19:27 #138945 by mickt
Read my topic "G13bb engine queries"
28 Feb 2015 15:42 #139428 by minibbb
Well my mate changed the mount for me today- safe to say the old one was knackered!
First and reverse seem a bit easier to engage. Need to investigate the bush in the gearbox re the stiffer gear changes.
Thanks for the suggestions gents!
Time to create page: 0.204 seconds
