Isuzu 1.7 TD conversion
- TomDK
23 Jun 2014 18:23 #118436
by TomDK
Isuzu 1.7 TD conversion was created by TomDK
How many of you have actually done this?
What gearbox are you using, I'm thinking the standard Jimny gearbox will be to low geared for diesel use.
How much power is it possible to get from the 1.7 TD? I know standard is around 82 bhp/ 168 Nm @ 2400 rpm. But the G16B engine is 95 bhp / 138 Nm @ 4000 rpm, and way cheaper.
So the 1.7TD would only be interesting if you could get more than 100 bhp / 200 Nm from it.
What I like about the G13BB/G16B is that you have lots of rpm available, with faster wheel rotation. Not sure I'll get that with a slow running diesel on standard gearbox.
- gaz3359
23 Jun 2014 20:14 #118439
by gaz3359
Replied by gaz3359 on topic Isuzu 1.7 TD conversion
Not done this conversion myself although im running an m16a in my jimny with a sj410 transfer box.when i did the engine swap was a good noticable difference.
i used to have have an astra g van that i fitted a 1.7td to after the dti gave up.i tweaked the max fueling fitted a bleed valve,did the white ring mod to the pump i also had it decatted and a bigger fmc fitted never had it on the rollers but it flew and had loads of torque and was reliable aswell whilst running on cooking oil mix.
- TomDK
23 Jun 2014 20:17 - 23 Jun 2014 20:18 #118440
by TomDK
Replied by TomDK on topic Isuzu 1.7 TD conversion
Thanks
What's the difference between 1.7TD and DTI engine? Thought the 1.7TD was a DTI?
What's and FMC?
What's and FMC?
Last edit: 23 Jun 2014 20:18 by TomDK.
- ARichards
23 Jun 2014 21:24 #118443
by ARichards
He might of meant to say FMIC, in which case 'Front Mount Inter-Cooler' which he probably did. Hope this helps
Replied by ARichards on topic Isuzu 1.7 TD conversion
TomDK wrote:
What's and FMC?
- TomDK
23 Jun 2014 21:38 #118444
by TomDK
Thanks.. makes good sense
ARichards wrote:
TomDK wrote:
What's and FMC?
- gaz3359
23 Jun 2014 21:48 #118446
by gaz3359
Yes sorry ment fmic. on my phone,the dti is a later 1.7 16v with electronic pump.the 17td is a proper manual pump 8v derv that will run forever.no electrics or ecu ect.
Time to create page: 0.196 seconds
