Snapped dipstick in a M13 DOHC and clutch cost?
14 May 2014 06:49 #115170
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Snapped dipstick in a M13 DOHC and clutch cost?
The yellow bit snaps off
I don't have one sorry
I do have a few good clutch cables though
Grey pick up Jimny
The following user(s) said Thank You: minibbb
- Thank you received: 115
14 May 2014 09:38 #115184
by maverick
Jalapeño, IISY?
Replied by maverick on topic Snapped dipstick in a M13 DOHC and clutch cost?
The top of my Yellow Dipstick snapped last year (not sure how) - but i got it out and drilled a small hole in the top and threaded wire into it, and then the wire is secured in engine bay -- as i also could not find a replacement Dipstick that suited my budget.
Regarding CLUTCH - try this www.clutchreplacement.co.uk/
Jalapeño, IISY?
14 May 2014 10:43 #115190
by minibbb
Replied by minibbb on topic Re:Snapped dipstick in a M13 DOHC and clutch cost?
Thanks for the input and help everyone
I couldn't see any dipstick whatsoever in my brief look at the engine bay so maybe the rocker cover will have to come off.....think I'll ask for a second viewing as forgot to check the 4wd worked ok whoops!
The gearbox seemed a fair bit stiffer than my much higher mileage 2005 jimny- likely to be related to clutch issues? Gearbox didnt crunch or anything and did go into each gear.
Would a garage easily be able to diagnose whether its the clutch cable or the clutch itself at fault?
14 May 2014 12:22 #115195
by Busta
Replied by Busta on topic Snapped dipstick in a M13 DOHC and clutch cost?
Gear shift weight shouldn't be affected by a worn clutch. If the clutch isn't fully disengaging then the gears might crunch but the lever action should still be light.
17 May 2014 20:17 #115568
by minibbb
Well we bought the jimny! The seller managed to get the snapped dipstick out and luckily only £15 from suzuki so a nice easy fix to that issue!
Re the clutch on looking at the car's service history it had a new clutch in 2010 at 68k (now on 75k) so it would seem unlikely the clutch itself has gone. I drove it again and the biting point was in the right place and it wasn't slipping, just graunchy and heavy so fingers crossed may just be a clutch cable. Going in the garage next week so shall see how it goes!
The following user(s) said Thank You: Busta
22 May 2014 14:25 #116019
by minibbb
New clutch cable fitted and problem solved, feels lovely now!
Time to create page: 1.697 seconds
