3" lift?
  • reaper
19 Mar 2014 21:24 #109167 by reaper
Replied by reaper on topic 3" lift?
TomDK wrote: Springs, shocks, longer brake lines and preferably castor correcting radius arms. You also need to install adjustable panhard rods or make the standard ones longer.
This is what you need . . . Anything less isnt going to do the job
  • idiotmobil
19 Mar 2014 21:26 #109168 by idiotmobil
Replied by idiotmobil on topic 3" lift?
can you explain what im missing out on with no adjustable panhard rods
  • Bigjim91
19 Mar 2014 21:31 #109169 by Bigjim91
Replied by Bigjim91 on topic 3" lift?
Mines only about an inch or so and obviously I can notice it and I hate it, looks all wrong
  • idiotmobil
19 Mar 2014 21:35 #109170 by idiotmobil
I don't notice mine very much mite be the landrover arches hiding it abit
I can see any other job for them to do other then centre it up and there stronger but standered ones are easyerly strengthened
I mite be missing some thing do they do any thing else?
  • reaper
19 Mar 2014 21:42 #109172 by reaper
As they are used to centralize the axles to the chassis if the are not set correctly then you are essensially crabbing as you drive , not only does this make an allready twitchy ride even more unstable but it causes unnessesary strain and wear on the whole drive line including tyres
On to saftey the stock rods are made of cheese and if you bend one you WILL roll the truck , on a standard jim this wouldnt happen but as you lift and pull the driveline out of scew it adds much more stress to the rods
19 Mar 2014 21:44 #109173 by robs5230
Replied by robs5230 on topic 3" lift?
has to be positives and negatives on this. having adjustable rods will as has been said centre the body over the axles meaning even weight distribution. conversely having adjustable rods adjusted incorrectly will mean your chances of ever having the tracking done are reduced to zero.
i have adjustable rods so i have no choice but as i use mine off road i'm happier that my weight is evenly ( or as evenly as possible ) distributed
standard jimny - for now
Time to create page: 0.170 seconds
