3" lift?
- TomDK
Bigjim91 wrote:
TomDK wrote:
Bigjim91 wrote: Waste of time goin 3" if you ain't going to get rid of the arb mate, defeating the object at the front
Why? Lift and suspension travel does not necessarily have anything to do with articulation.
I agree, that most remove the ARB for better articulation. But it is not a must.
Wats the whole point of a suspension lift then. Have u still got your roll bar on
As i just wrote.
Why do you think many comp trucks have swaybars fitted? I know these swaybars are torsion-bars that stilll allow some articulation. But they are fitted to reduce body-roll, just like the ARB. Which is why some may want to keep their ARB on, also to reduce body-roll when offroading.
I have removed my ARB. But wil try putting it on again to reduce bodyroll when offroading. This of course mostly when drive along slopes, and not just up and down them
I know most of us don't drive comp trucks. But with a 3-4" lift, body roll is increased.
- Dave cc
- Basketcase
- Thank you received: 51
- jonesyba420
- JerseyJimny
jonesyba420 wrote: how is it to drive on the road with the caster being wrong?
I don't notice it tbh... It doesn't self center the steering as well but other then that I didn't notice a difference
Mine has recently started pulling to the right but I think it's because when you lift a vehicle the axles go out if center so they are stuck out more on side then the other... This is cured with adjustable panhard rods
Sent from my SM-N9005 using Tapatalk
- idiotmobil
Dave cc wrote: Don't want to enter into a argument but a 3 inch lift cant shift the body over by a inch let alone a 2 inch lift do the maths it don't work out guys :whistle:
I worked out that if a panhard was 48 inch ( got to be around that cant measure as im at home) then you go up 3" then it only gets 0.9 of a inch longer been awile since had to work that out so mite be wrong
